Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Another Homegrown STB!
Old Mar 22, 2005 | 11:01 AM
bulletboy29's Avatar
Car: '87 Camaro SC
Engine: 305 LG4
It's a tight fit, but it works with the stock air cleaner for now.
Old Mar 24, 2005 | 09:20 PM
Car: '87 Camaro SC
Engine: 305 LG4
I've noticed that it's much tighter in curves. Now if I could just put a 350 under that STB!
Old Mar 25, 2005 | 12:46 AM
MaxxMitchell's Avatar
Car: 87 Firebird
Engine: 5.3 76mm
Transmission: Rossler TH400, PTC converter
Axle/Gears: Strange 12bolt, 3.08s
Looks good, gives me a good idea for mine ^_^ I will be tieing mine into the cowl area, to stiffen it that much more. Look at the Edelbrocks TBI set up to see what i mean.
Old Mar 25, 2005 | 03:42 PM
Cyfun's Avatar
Car: '83 Trans Am, Black on Red
Engine: LG4 305ci V8 w/ CCC-Qjet
Transmission: Rebuilt 700r4
Axle/Gears: 4th gen 2.37 posi w/disc brakes
Wow, that is pretty nice for a homemade STB. Makes me want to get started on one for myself.
Old Mar 28, 2005 | 10:35 PM
theshmo891's Avatar
hmm, pics arent showin up, and i wanna see it
Old Mar 29, 2005 | 05:52 AM
JPrevost's Avatar
Car: 91 Red Sled
Very nice. Interesting choice of color but to each his own. Good design and very effective.
Old Mar 29, 2005 | 03:16 PM
Car: '87 Camaro SC
Engine: 305 LG4
The red paint adds around 15hp! I thought all high performance bolt-on parts had to be red. Isn't that the rule or is it blue?
Old Mar 29, 2005 | 06:47 PM
Cyfun's Avatar
*shrugs*
I always thought it was plum purple...
Old Mar 30, 2005 | 02:54 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I like how you attached the tube to the brackets- looks cool, and must be a bit stronger than raising the bracket up and bolting the tube to the bracket.
Good place to hide some nitrous lines, too.
Old Mar 31, 2005 | 11:42 PM
82knightrider's Avatar
Transmission: TH200C....700R4
Old Apr 2, 2005 | 07:35 PM
Car: '87 Camaro SC
Engine: 305 LG4
Many STB's are red. Here is an example:
Attached Thumbnails Another Homegrown STB!-c-documents-settings-lucy
Old Apr 2, 2005 | 10:18 PM
icarus402001's Avatar
Is there a bend in the middle?
Old Apr 2, 2005 | 11:07 PM
Car: '87 Camaro SC
Engine: 305 LG4
No bend in the middle.
Old Apr 8, 2005 | 10:38 PM
Cyfun's Avatar
Just threw together an STB using $10 of scrap metal. Used 1/8" thick 1 1/4" square pipe, but its pretty much the same design as bulletboy's. It's rather overbuilt, but took only half a day to put together. There is quite a noticeable difference in handling. I'll post pictures as soon as I find a digital camera.
Old Apr 8, 2005 | 10:59 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Sorry this took so long to ask, I keep forgetting:
bulletboy, care to share any specs?
length of tube, wall thickness, diameter? is that 1/8" for the plate? how did you bend it?
I'm thinking of doing mine VERY similar to that design, simple, and useful with stock aircleaner.
Old Apr 9, 2005 | 02:31 PM
Cyfun's Avatar
My design is identical to bulletboy's, aside from my using square pipe. The tube length is 4 feet even, the wall thickness is 1/8", the diameter is 1 1/4", and the plates are 1/8", and it isn't bent at all. I'm using a stock air cleaner, too.
This is a surprisingly easy job if you have access to a good scrap metal place and a welder.
Old Apr 9, 2005 | 02:47 PM
Car: '87 Camaro SC
Engine: 305 LG4
The bar is 48 1/2" long and the thickness is 1/8". The brackets are 1/8" thick too. The diameter is 1 1/4". The bar isn't bent, I think the glare just makes it look that way. The color is red. lol
Old Apr 9, 2005 | 02:51 PM
Car: '87 Camaro SC
Engine: 305 LG4
Originally posted by Cyfun
My design is identical to bulletboy's, aside from my using square pipe. The tube length is 4 feet even, the wall thickness is 3/16" or 1/8", the diameter is an inch or a lil above, and the plates are 1/8", and it isn't bent at all. I'm using a stock air cleaner, too.
Post your pics!!! Are you going to paint yours plum purple?
Don't wimp out on me and paint it black!
Biochem
Aftermarket Product Review
Jul 6, 2001 11:10 PM
Stell1579
Feb 1, 2001 10:47 AM
Joe's-88
Nov 26, 2000 09:30 PM
