Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Camaro Tunnel Work
Old Apr 18, 2005 | 01:08 AM
JeremyNordan's Avatar
Camaro Tunnel Work
Hi I'm looking at an 84 camaro, But to do what I want to with it I know I need tunnel work-and I don't know how to go about it. If someone here knows about tunnel work please explain to me what needs to be done for me to put a T-56 6 speed transmission in the car, and a 454 big block.
The tech guy from Richmond Transmission told me tunnel work would have to be done in order for the transmission to fit, because the origional tranmission sits at an angle due to a torque bar.
Old Apr 18, 2005 | 07:31 AM
406TPI's Avatar
Car: 1985 IROC-Z
Engine: Magnacharged LS1
Axle/Gears: Ford 9" 4:11's
T56 into a 3rd gen needs no "tunnel work" Fits right in without any problems.......not sure about the big block though....might want to check with some of the guys that have done it to see if there are any clearance problems with the firewall.
Old Apr 21, 2005 | 01:20 AM
smokefan's Avatar
Car: 86 IROC w/Danko bodykit, 1988 iroc vert, 1989 k1500 pickup 6" lift and 35" tires, 2002 chevy tahoe z71
Engine: 383 stealth ram, 305 tpi, 350 tbi, 5.3l
Transmission: T56, 700r4, 700r4, 4l460
they are right about the angle of the transmission. did he tell you that they make an adapter plate that you need to use also that will allow you to use a lakewood shield.
Old Apr 23, 2005 | 04:25 PM
1983Fbody's Avatar
Car: transam, el camino
Engine: 415
My LT1 T56 fit with a little trim job, most people just slide them into place with no problems. The tranny I put in was hitting by the shifter area so you might have to use a grinder or a hammer it's not that big of deal though it was maybe 1/2" strip of metal that was in the way.
I'd consider using a Tremec TKO behind that big block, depending on how serious the engine is. Is that camaro a manual transmission car? It's a pain to convert over to a hydraulic clutch, almost easier just to start with a 5speed car right from the start.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
Fronzizzle
Aug 9, 2015 01:15 PM
