Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
BIGGER is better! ;)
Old Jun 3, 2005 | 08:30 AM
Liquid_Metal's Avatar
Car: Red '89 GTA
Engine: TPI LB9
This is off of a mitsu turbo picup and it's as Donald Trump would say..... UUUGE!!
I did some quick fabrication and voila it slid right into place.
This has to give atleast a couple extra hp compared to the stock filter. Anybody dare to guess how much and what do you think of it? It's not that pretty but keep in mind it only cost me like 10 bucks the whole thing
Old Jun 3, 2005 | 08:34 AM
Car: Red '89 GTA
Engine: TPI LB9
Here's another pic.....
Old Jun 3, 2005 | 08:37 AM
Car: Red '89 GTA
Engine: TPI LB9
yet another.....
Old Jun 3, 2005 | 12:01 PM
Forshock 85TA's Avatar
Car: 85 Trans Am
Engine: 350 (CCC QJet)
Axle/Gears: 3.08 9 bolt
Thats pretty friggin big. Any gains? of course for $10
Old Jun 4, 2005 | 04:42 AM
Car: Red '89 GTA
Engine: TPI LB9
I'm not sure.... it certainly feels like it.... but don't know if that's just suggestive thinking
Old Jun 4, 2005 | 05:52 AM
83 Crossfire TA's Avatar
Um, Ok, you had an SLP cold air (judging from the ducting), you got rid of it and replaced it with a filter that is able to suck hot, underhood air in… I think at one point I took K&N’s equation and found that the stock size filter was good for something like 450hp, so unless you’re making significantly more then that, you probably lost power by sucking in the warm air now.
Old Jun 4, 2005 | 08:37 AM
Car: Red '89 GTA
Engine: TPI LB9
I seem to be having a case of Godzilla..... where bigger seems to not be better after all
Old Jun 4, 2005 | 10:55 PM
355gta's Avatar
Car: 1989 pontiac firebird trans am gta
Engine: 355
Axle/Gears: 327:1 9 bolt
I must be missing something. that ducting is the same as my stock. unless you guys know he had it previously.
Old Jun 5, 2005 | 04:39 AM
Car: Red '89 GTA
Engine: TPI LB9
I certainly haven't done any mods to the ducting. I think it's stock MAF.... but don't know if the previous owner has done anything to it.
Old Jun 5, 2005 | 04:47 AM
355gta's Avatar
Engine: 355
The only reason isaid that was because somone said he could tell by the ducting thta you had an SLP cold air intake,but that is stock.
Old Jun 5, 2005 | 03:28 PM
Crappy picture, but this is the stock intake assembly:
Old Jun 5, 2005 | 03:36 PM
and this is an SLP cold air assembly (ignore the turbo sitting behind it):
Old Jun 5, 2005 | 04:04 PM
Car: Red '89 GTA
Engine: TPI LB9
the ducting seems to be the same right up to the filterhousing. I don't have a good pic of it but it was cylindershaped and had a pipe pointing to the front for colder air I guess. But the small filter inside just seemed so restrictive in flow so I thought I'd try this much larger filter instead.
So these aren't stock parts in my car? What are they then?
Old Jun 5, 2005 | 05:13 PM
355gta's Avatar
Engine: 355
The only thing i see in that picture is a slp cold air box. That is the stock ducting, just like on my car and many others that i have seen.
Old Jun 8, 2005 | 01:27 PM
88 WS6 TransAm GTA's Avatar
Car: 92 Trans Am 'Vert
Transmission: 5 Speed
Thats stock 88-89 ducting.
Old Jun 8, 2005 | 01:30 PM
Dan8289gta's Avatar
Car: 89 GTA
Engine: 350 tpi
My 89 gta has the same ducting, that is stock.
Old Jun 8, 2005 | 02:40 PM
Tom 400 CFI's Avatar
Engine: LT1, L400
Transmission: ZF6, T5
Axle/Gears: 3.45, 3.31
I agree it's stock ducting.
But I also agree that that HUGE hot air intake is not helping hp at all. I saw a stock looking TPI in the back ground of the first pic. I don't think the air filter size was holding that combo back.
Old Jun 9, 2005 | 01:52 PM
Formula 89 Bird's Avatar
Car: 89 Formy
Engine: 305--->TPI 350
Transmission: auto :(
It's stock ducting, nothing slp about it . 83 Crossfire TA - hows that setup coming, by now I'd expect you to have a running turbo setup for how much "advice" you give.
Old Jun 10, 2005 | 09:13 AM
black89ws6's Avatar
Car: 89 Formula, WS6
Engine: LB9/peanut cam :(
One more vote for stock ducting...that's what came on my 89
Old Jun 15, 2005 | 06:56 AM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Mark,
SLP used the factory ducting for 88-92 TPI cars, and just added an air box. Back when people actually used to like these cars, and had money at the same time - I would sell a lot of these 88-92 ducting setups.
Suposedly, between the 'newer' ducting, and the dual cat option, the TPI cars picked up something like 15hp.
Which is prolly the same as 1 degree of timing on our cars
-- Joe
Fronzizzle
Feb 9, 2017 09:31 AM
KNIGHTE
Southern California Area
Oct 22, 2015 09:11 PM
sjorgens
Oct 1, 2015 07:54 PM
rubyred88
Sep 17, 2015 02:19 PM
87hellbird
Sep 14, 2015 05:08 PM
