Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
modify 91 350 ignition, help needed
Old Jun 3, 2005 | 11:45 PM
Firebirdjim's Avatar
Hello,
I am repairing my 91 GTA L98 350. I want to replace the stock ECM with a FAST XFI, Acell DFI or AEM ECU. FAST XFI system seems to be the easiest. Anyway, I intend to create a coil per cylinder, distributorless crank triggered ignition system.
I need to eliminate the stock distributor as my new custom manifolds and plenum will not allow it.
Correct me if I am wrong PLEASE.
I believe the HEI distributor preforms three functions other than spark distribition:
1. Provides the Tachometer signal ???
2. Drives the oil pump ???
3. Hole in distributor shaft lubricates the rear of the camshaft ???
Problem: If I eliminate the stock HEI Distributor;
1. How do I generate a signal to run the Tachometer ?
2. How do I lubricate the engine properly at any RPM ?
3. Not sure how necessary this is since no distributor gear to lubricate.
Please reply directly to
Firebirdjim@hotmail.com
Need some helpful advice.
Old Jun 4, 2005 | 05:26 AM
JoBy's Avatar
Car: 1984 Corvette
Engine: Turbo 350
Transmission: 4L80E with TCI T-Com
1. yes
2. yes, you need the lower part of the distributor to drive the oil pump or convert to dry sump.
3. No, it provides oil to the right side lifters and rockers.
You have to take an old distributor and modify it. Remove all electical parts. You can use a lathe to minimize the size where it does not clear the plenum.
The new ignition system probably has a tachometer output you can use.
Old Jun 4, 2005 | 05:49 AM
83 Crossfire TA's Avatar
use a distributor drive out of an LT1 (yes, they have one under the manifold even though they don't use a distributor)
Frozer!!!
Jan 19, 2024 04:55 PM
IROCZ1989
Jan 24, 2016 03:55 PM
NinjaNife
Aug 23, 2015 11:49 AM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
