Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
LT1 intake and heads
Old Nov 9, 2005 | 10:56 PM
mlewis's Avatar
with a 1991 L98 out of a corvette, with a converted LT1 intake fit on there with the stock heads without any sealing or leaking problems, or will i have to replace the heads??? Thanks
Old Nov 10, 2005 | 11:22 PM
NEEDforSPEED's Avatar
yes, you just have to re-drill the holes, theres so many threads on this did you try searching yet?
Old Nov 13, 2005 | 06:21 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
I'd just modify some LT1 heads and use an LT1 intake. This way you get the better LT1 heads and intake. The hardest part of the intake swap is drilling holes. So why not just bypass that and do the heads too?
Old Nov 18, 2005 | 01:24 AM
junkcltr's Avatar
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
The LT1 intake will not completely cover the EGR ports on the heads. You need to weld pieces onto the intake to block the port completely or it will pump exhaust into the lifter valley.
Make a template of the LT1 intake port surface and place it on the head. You will see the 1/4" to 1/2" gap at the bottom of the EGR port on the head.
Old Nov 22, 2005 | 05:45 AM
Z69's Avatar
Z69
I didn't know corvette AL heads had EGR ports......
Corvette Heads
Get to the dyno yet Mark?
Old Dec 1, 2005 | 04:12 PM
junkcltr's Avatar
Engine: 3xx ci tubo
I did a poor job of reading the initial post and assumed steel heads. So my comments do not apply in this case. I do not know what is required with the alum heads.
I used an LT1 intake with some older steel smog heads and it has been working great. Probably one of the best intakes I have ever had.
J
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
hayesaw0210
Aug 23, 2015 11:15 PM
theurge
Aug 21, 2015 12:46 PM
