Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Best place for hood pins
Old Jan 27, 2006 | 09:19 PM
JayBanion's Avatar
Car: 1986 Pontiac Firebird
Engine: Modified Chevy 350
Transmission: 700-R4
Axle/Gears: GM 10 bolt 3.73 gears
I just purchased a new pin-on cowl hood for my 86' Firebird. Where is the best place to locate the hood pins. I know the best place for the 2 pins in the front is to mount them on the radiator support. But to hold down the rear of the hood where is the best place to mount those. Thanks
Jay Banion
Old Jan 27, 2006 | 11:12 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Where ever works best. I only use the front 2. If you have to, weld on some gussets out from the cowl to move the pins to a location that works best.
Old Jan 31, 2006 | 04:54 PM
brutalform's Avatar
Darn pic is too big.
Old Jan 31, 2006 | 05:00 PM
brutalform's Avatar
Ill try again. This was the best spot for me.
Old Jan 31, 2006 | 05:01 PM
brutalform's Avatar
OOPPPS. I just saw you already have a good place for the front mounting.
Old Feb 6, 2006 | 10:22 PM
jack_sparrow's Avatar
Car: 1985 Camaro
Engine: 350 bored 40 over
Transmission: 700-R4 Race prepped
I made mine a fiberglass lift-off and used the old hinges to make a mounting point that attaches to the rear firewall top, and also bolted to the pinch weld of the frame rail of the fender and body. If you look closely in the photo you can see the mounting for the hood pin in the top center of the pic. BTW if have Mr. Gasket locking hood pins.
Brett
Hotrodboba400
Dec 10, 2019 07:07 PM
scottmoyer
Sep 7, 2015 07:06 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
SlowAZ28
Sep 2, 2015 05:19 AM
