Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Welding Cast Aluminum?
Old Feb 2, 2006 | 05:36 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Hey,
Can thing sheet aluminum be welded to thicker cast aluminum? I ask because I have a set of aluminum valve covers that have no baffles, and I was just going to make a set from some thin sheet aluminum, and maybe just have a shop tack them in place for me.
Can thin sheet aluminum be welded to thicker cast aluminum? It just needs to be tacked in a couple spots to hold them in.
Old Feb 2, 2006 | 07:46 PM
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
it can be done but it sounds like you're asking for (needing) someone to do it who is good with a TIG welder.
Old Feb 2, 2006 | 10:20 PM
RebelRacer's Avatar
Car: Bitchin' 92 RS
it will be just like welding any aluminum, the same, just don't it too hot or you will blow through the thin stuff
Old Feb 2, 2006 | 11:44 PM
sixpackmtrspts's Avatar
just make sure everything is really clean, and a good tig welder helps
Old Feb 3, 2006 | 04:29 AM
83 Crossfire TA's Avatar
It can be done assuming that both are made of weldable grades of aluminum. Flat sheet stock and castings can be made of grades that are not weldable, and weldingany aluminum makes it weaker (the reason that as bonding/glue technology gets better, aluminum gets more common in car parts/bodies)
6speedIROC
16
Mar 15, 2023 08:33 PM
gixxer92
May 18, 2017 11:20 AM
skinny z
Oct 5, 2015 06:23 PM
6998poncho
Sep 25, 2015 02:56 PM
355tpipickup
Sep 13, 2015 11:35 PM
