Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
stb thickness
Old Mar 21, 2006 | 06:18 PM
z28z34man's Avatar
Car: 1984 z28 camaro / 2019 accord sport
stb thickness
would 1/16" thick 1" square tubing be to thin for a stb. when bending it to fit around the air cleaner it seamed pretty ridged. i weigh 225# and i had to jump on several times to get the bend.
Old Mar 21, 2006 | 06:32 PM
fitbmxseries1's Avatar
Car: 1988 trans am GTA
Engine: 350 tpi
stiffer the better! this bar is ment to be very stiff so it doesnt just flex when your driving cause if it did that there would be no point on having it
Old Mar 27, 2006 | 10:55 AM
drex's Avatar
Car: 87 formula and 85 olds delta 88 2 d
Engine: 60's 350 holley carb and intake
Transmission: muncie 4 speed with centerforce
Axle/Gears: 3.42 99 camaro rear w/ discs
i have made about 8 stb's from 1x1 square 1/16 " that is strong but instead of jumping on it make it straight across or cut notches and re-weld it to go over a intake or something.. works well feel the difference first time out.
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
roysatikas
Sep 22, 2015 08:15 PM
sahlomonic
Sep 20, 2015 07:15 PM
Magman
Sep 12, 2015 11:55 PM
lee01
Sep 10, 2015 06:18 AM
