Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
subframe repair
Old Mar 30, 2006 | 10:40 PM
doug86z's Avatar
Car: 86 z28,
Engine: 1978 350 bored 0.30 over
subframe repair
The subframe around the tranny xmember is rotted. I was just wondering if anyone out there has had this problem and if so what you did about it. I really don't want to scrap this body just for that as this is the only thing wrong with it.
Old Mar 31, 2006 | 04:01 AM
Xophertony's Avatar
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Transmission: Automatic
Axle/Gears: n/a
well... you will have to cut out the damaged section and replace it with a section cut from a non-rusty car. adding additional bracing might be a good idea as the graft may not be as strong as the original solid piece. i am of course reffering to SFCs.
Old Mar 31, 2006 | 08:37 AM
Ratchet's Avatar
My Sons first car had the same problem. We cut out the rust then cut a piece of square tubing to fit. Cut out the back of the square tubing so it was more like a piece of channel iron then drilled for the transmission mount holes and welded nuts inside the channel. Then welded it solid into the car. If you are not a welder or don't have a good welder do the fabrication yourself then take it to a welder and get them to weld it in. It will be better than new.
Ric
Old Apr 3, 2006 | 04:17 AM
83 Crossfire TA's Avatar
I've fixed one where the extra forces placed on it by a t56 crossember caused it to crumble and fall appart... ended up stitching the stock stuff back together and then welding some reenforcement onto it...
SRKLEGIN
Sep 30, 2015 07:19 PM
Aaronv808
Members Firebirds
Sep 30, 2015 12:55 PM
tmork454
Sep 29, 2015 06:33 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
ironbmt
Sep 27, 2015 06:00 AM
