Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
TA Pinion Angle Adjuster
Old May 23, 2006 | 02:28 AM
83 Crossfire TA's Avatar
Any idea where to get this assembly?
Old May 23, 2006 | 04:53 AM
powermite's Avatar
Car: Transam
Engine: ZZ4,Holley Stealth Ram,Commander 950
Well the whole adjustable torque arm is from Spohn Performance but if is just the bit you circled thats just a spherical rod end.
Spherical Rod End Directory - Midwest Control Products Corp.
PM
Old May 23, 2006 | 10:45 AM
Kat's Avatar
Kat
Car: Camaro Vert
Engine: 355 HSR
Transmission: A4
Axle/Gears: 3.73 S60
Thats a BMR peice and if you want, Steve Spohn will sell you just that turnbuckle and soild rod end if you can't find one anywhere else.
Old May 25, 2006 | 04:32 AM
huh... what do you mean by solid rod end, that there is no pivot ball used in there?
Kat, I PM’ed you…
Old May 25, 2006 | 06:00 AM
powermite's Avatar
Car: Transam
yes there is a "pivot ball"in there
PM
Old May 25, 2006 | 08:08 AM
Kat's Avatar
Kat
Car: Camaro Vert
Engine: 355 HSR
Transmission: A4
Maybe BMR has a "piviot ball" back there but I know Spohn's don't. there is no side to movement back there, aside from making it easier to adjust the rear, what is the point of having a regular rod end back there?
Old May 25, 2006 | 10:11 AM
powermite's Avatar
Car: Transam
ive got a spohn and the joint is a standard spherical rod end ,not soilid
PM
Old May 25, 2006 | 03:15 PM
fb305svs's Avatar
Car: 1991Firebird T/A
Transmission: Modified Viper t-56
Axle/Gears: dana 44, 3.55
thats a bmr torque arm in the pic... not sure where you would get those parts - hopefully spohn can get you a set could even try to contact BMR -
Old May 26, 2006 | 10:43 AM
Project86's Avatar
Try S&W Racecars Part #40-214 comes 2 to a package. Page 34 of the catalog I have. $25.95
Old May 31, 2006 | 06:38 PM
Kat's Avatar
Kat
Car: Camaro Vert
Engine: 355 HSR
Transmission: A4
PM
I've prolly put together over a thousand of spohn torque arms together when I worked there. They are a soild rod end. Don't argue, you are wrong.
Old Jul 10, 2006 | 12:59 AM
86irocterror's Avatar
what is a "solid rod end" and a "spherical rod end" my spohn torque arm moves side to side with the rod ends, i had it only bolted to the rear when installing it and it swung side to side. but i know they are solid rod ends. it even says it in the paper work. but i got it with a spherical front rod end i think. it was 15 bucks more for the front mount, im just asking what the difference is since you would know after working at spohn. i go there to pick up my stuff and love the guys there.
Old Jul 10, 2006 | 01:01 PM
jaykar's Avatar
Car: 87 Iroc Showcar - Saturday Nite Hun
Engine: 383 4-Bolt Truck Hyd Roller MiniRam
Transmission: B&M 700R4 - Edge 3200
Axle/Gears: BW 9 Bolt-TA Cover & Stud Kit - 3.2
Swivel
Have the complete Spohn setup including the adjustable
Torque arm on my car and on the rear is a swivel Hiem
joint and screws into tube in front with a jam nut.
Nice people there as they even powder coated all the
pieces there in OEM Iroc gold trim to match the trim on
the car at no extra cost.
Later
Irocing
Old Jul 14, 2006 | 07:22 PM
Kat's Avatar
Kat
Car: Camaro Vert
Engine: 355 HSR
Transmission: A4
A solid rod end doesn't have the sperical ball in it. It is all one peice.
Regular sperical rod end
Hope that clears that up.
Later
Irocing
Ahh so your the guy that got that! I remember sending them out to ya.
Old Jul 15, 2006 | 05:38 PM
jaykar's Avatar
Torque Arm
Hi,
Yup,
And everythings installed and setup except the relocation
brackets and will get them in next week. Then find out
if I can put it to the ground.
New horse and still chip burning. Lotta nice comments
on the gold powder coating as I got everything you guys
have for it except the wonder bar, and that comes with
the Iroc.
Later
jaykar
Old Jul 16, 2006 | 10:36 AM
Kat's Avatar
Kat
Car: Camaro Vert
Engine: 355 HSR
Transmission: A4
Hi,
Yup,
the Iroc.
Later
jaykar
I'm thinking of someone different. I know a guy ordered some gold stuff about 2 years or so ago when I was there. lol I'm thinknig you were him. lol
Old Jul 22, 2006 | 06:21 PM
jaykar's Avatar
Spohn
Hi,
I ordered and got my suspension piecs about 6 months
ago.
I'll be posting pics once I learn how to downsize them
and post them.
Later
jaykar
InfernalVortex
Apr 20, 2021 11:31 AM
Cole Curtis
Theoretical and Street Racing
Oct 3, 2015 12:26 AM
meeklay812
Oct 1, 2015 03:46 PM
gord327
Sep 29, 2015 10:18 PM
mfp189
Sep 27, 2015 09:25 AM
