Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
rim question
Old Nov 22, 2006 | 07:32 PM
sLoW'n'StEaDy's Avatar
rim question
I am wondering what, if anything needs to be done to fit a set of nice wide wheels in the rear of my 88 TA.
i want either 15X10 or 15X12 (i WANT 15X12 but if 15X10 would be much easier i can jus go with those.) Also, i wont be keeping them on all the time, just for "special occasions"
Thanks in advance
Old Nov 22, 2006 | 10:33 PM
BBCAM's Avatar
Car: 99 Camaro
Engine: LS
Transmission: TH-400
Axle/Gears: 3.25 9"
Either is going to be a challange with a stock rearend and wheelwells the widest I have seen fit is 15x10 with a 5" backspacing and those were in danger of hitting the outer lip of the wheelwell.. and you can't cut enough things out of the wheelwell to make any difference on the cars because of the suspension and frame if you want big tires do what I did and TUB it !!
Frozer!!!
Jan 19, 2024 04:55 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Djmathis123
Sep 29, 2015 01:36 AM
redmaroz
Aug 16, 2015 11:40 PM
Exxon Limited
Aug 9, 2015 08:13 PM
