Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
fun ideas?
Old Jan 5, 2007 | 11:30 PM
slowfast's Avatar
Car: 84 firebird
Engine: 400 sbc
Transmission: th350
Axle/Gears: 3.08
fun ideas?
Hey guys I need some help finding a use for two front gta wheels that are bent. Id like to make something or mout something to it. maybe a shelf? idk help me out with some ideas!
Old Jan 5, 2007 | 11:55 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
coffee end tables?
Old Jan 6, 2007 | 03:26 AM
ws6gta89's Avatar
Car: 1989 TRANS AM GTA
Engine: 355 L98
Transmission: Built 700r4
Axle/Gears: BW 3.27
turn them into a grill i saw a guy at the turkey rod run who did it it looked pretty kool,you could also use them for the base of a bar stool
Old Jan 6, 2007 | 10:11 AM
Jtufts's Avatar
Car: 1989 camaro rs
Engine: 305 TBI
Transmission: 700r
a guy down the block used a brand new z06 set of rims and made a flag pole , i cried alittle inside and wanted it
Old Jan 6, 2007 | 03:40 PM
mike_c's Avatar
Car: 1989 Trans Am GTA
Axle/Gears: 9 Bolt 3.70
Maybe you could turn one into a clock? That might be kinda cool.
Old Jan 6, 2007 | 03:55 PM
Comp788's Avatar
Car: 1982 Z28 & 1967 RR/SS 396
Engine: ZZ383 & 375hp 396
Transmission: T56 & factory TH400
Axle/Gears: 9" ford & 12 bolt 4.10
That would be very cool. Even better if you cut the wheel down to just below where the bolt bolt up so it was not so thick.
83 Crossfire TA
Jan 3, 2016 01:26 PM
TrevinE
Sep 14, 2015 03:20 PM
Nick McCardle
Sep 10, 2015 08:36 PM
Fronzizzle
Sep 8, 2015 12:10 PM
