Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
whats the best way
Old Jan 25, 2007 | 01:11 PM
bigmaciroc's Avatar
whats the best way
does anybody have a better way to cut a perfect 15" circle in a hood besides and cut off wheel and trim the rest with a die grinder? any ideas serious will be helpful. thanks
Old Jan 25, 2007 | 01:16 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Air nibbler.
Old Jan 25, 2007 | 02:18 PM
Kenwood's Avatar
Car: 1987 GTA
Engine: PT88 Turbo DART 406
Transmission: th400
Axle/Gears: 9" ford
If you get a fine tooth jigsaw blade and the cirtcle attachment(usually included with the jigsaw) you can cut a perfect circle in the hood.. Basically you drill a hole in the exact center of the hood.. then the centerig jig locates off that hole.
Old Jan 25, 2007 | 02:37 PM
Blownz28man's Avatar
Car: 92 25th anv z28
Engine: 346 TC78 Turbo
Transmission: 4L80E
Axle/Gears: 3.25 9"Nodular, Strange axles
Jig saw would work. Also check an air saw. Harbor freight has them on sale right now for 20-30 bucks. Perfect for trimming body parts. And plastic too!
Old Jan 25, 2007 | 04:12 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
i did mine with a sawzall and it came out well, but i had no intention of keeping hood for more that a couple months. a bit of advise though, the engine is NOT in the center of the car so pick up an offset aircleaner so you can cut the hole in the middle of the hood. if you dont it will look like a$$ and you WILL regret it.
Old Jan 25, 2007 | 04:35 PM
maroon88iroc's Avatar
Car: 88 IROC
Engine: 305 TPI w/ l98 cam
Transmission: T5 5-speed
Axle/Gears: 3.45 posi disc 9 bolt
i would really love one with a safety loop and TA mount that would be very cool!
edit: wow i really replied to the wrong thread sorry.
Old Jan 25, 2007 | 09:00 PM
bigmaciroc's Avatar
how off center is the engine?
Old Jan 26, 2007 | 02:25 PM
Camaro355Z28's Avatar
Car: '86 Z28
Engine: 355
Transmission: 5 speed
Axle/Gears: standard 3.23
I took a 15" piece of string and tied it around the air cleaner stud, and a sharpie around the other end and puled the string tight and went around in a circle underneath the hood to make a hole perfectly around for the air cleaner to fit through. jigsaw worked best for me...
Old Jan 29, 2007 | 01:14 PM
turbochargedrs's Avatar
Car: Fire Red 89 RS
Engine: 2.8L :(
Transmission: 700r4 auto
you could always just measure to where the center of the cleaner is and drill a small hole now use a circle cutter from home depot or lowes to make your mark on the hood. its pretty much a spine atached to a rod with a wheel on the end and if you push a little bit it should scratch out the circle perfectly. then you can go at it with a number of things including a jigsaw or sawzall or even a rotozip with a good bit in it(if your hood is fiberglass), or a plasma cutter. there are a number of tools to do this stuff with but you deffinately need to make sure your mark is made perfectly otherwise it will look shitty.
Old Jan 29, 2007 | 05:36 PM
Mathius's Avatar
Why not put a bolt in for your center hole, and make a little jig to hold your plasma cutter or nibbler or whatever, and just run a circle with it. Same idea as a pencil compass.
Mathius
Old Jan 29, 2007 | 08:26 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
about an inch i have a 1.5 offset aircleaner and it works well for me
