Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Propless hood?
Old Feb 16, 2007 | 10:10 PM
Naga1337's Avatar
Propless hood?
So my dad got a Hyundai Sonata, and it's hood doesn't use a prop rod. It uses hydraulics, but I don't know the specifics, he won't let me get a "good look" if you know what I mean. I'm just curious to know if this has ever been done before, as I think it'd look pretty neat on a Camaro.
Old Feb 16, 2007 | 10:16 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Umm... Camaros don't use prop rods either.
Old Feb 16, 2007 | 10:28 PM
Tmic87TPI's Avatar
Car: 1987 Trans Am
Engine: 355
Transmission: t56
Old Feb 16, 2007 | 10:53 PM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
they do when the support struts are bad
< me under the hood of someones car right after they decide to let the hood drop
< me 30 seconds later
Old Feb 17, 2007 | 12:48 AM
novatuc's Avatar
Car: 1984 Trans Am
Hood struts are cheap. Why would you waste time on a hood prop? I'm in Canada and they are like $17 each.
Old Feb 17, 2007 | 01:50 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
I was hoping he meant 2nd gen camaro style, no rod, no gas strut. Just that funny round spring dealy. THAT'S neat. It doesn't wear out like a strut, etc. Probably a reason why it was phased out tho.... Anyone?
Old Feb 17, 2007 | 08:57 AM
ChillPhatCat's Avatar
Car: '10 Subaru Forester
Engine: 2.5 Boxer
Transmission: 4EAT
Axle/Gears: 4.44
Well the hood strut/hinge assemblies are much lighter, the stock spring/hinge assembly on my '74 weighed in at 13 lbs a piece . The spring hinges also get rusty over time and make it a chore to lift the hood, but that could be prevented with good greasing.
Old Feb 17, 2007 | 09:01 AM
Vader's Avatar
Would that be a third-generation Hyundai?
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
91TTOPZ
Exterior Parts for Sale
Sep 20, 2016 12:42 PM
