can regular valve covers be modified to fit center bolt??
Car: 89 camaro rs
Engine: 305 tbi soon 78 lt1 400hp
basically i was going to get a new engine then ran out of cash but have a whole flame valve cover set and was wondering if there was any way to make it work for a center bolt style i know theres adapters but they are expensive as hell so its prolly not to simple but i'm out of cash so i'm looking for ideas.. any help would be good thanks adam...
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: can regular valve covers be modified to fit center bolt??
anything is possible with enought time and money, but no i do not believe you can just drill holes in the covers and bolt them on.
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
there are adapters to go both ways; from centerbolt to outer perimeter bolt and the other way
I think I saw them in Jeg's...
Car: 91 z28
Engine: 383 sbc, 88mm turbo a2w IC, CSU 750
Transmission: th-400 PTC 4000 stall
Axle/Gears: ford 9" 3.55 gear
Back to the subject, you're probably going to have to either sell those to buy centerbolt ones, get some off a junkyard car, or try to trade the ones you have to someone that has centerbolt looking for perimeter
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
i see stock LT1 style valve covers pop up over on ebay pretty cheap. any gen 1 sbc 87+ will have them.
Car: transam, el camino
Engine: 415
I have a set of centerbolt flamed valve covers I'd trade for perimeter bolt style. Also a set of stock centerbolt valve covers I would basically give away.
My ebay ID is freemanben if you want to check my feedback.
NBrehm
Aug 25, 2015 11:49 PM
Street Lethal
Aug 12, 2015 11:33 AM
