school project for v6, startin to get ideas need some help guys!
Car: 92 Chevrolet Camaro RS
Engine: 3.1L V6
Well guys, I school starts in about 20 days. i'm goin to be a junior and pick a metal based projects class. so i go this idea to build Eaton superchargered 60* V6. Ya I know just do a turbo, its easy. i want to be different lol. since my welding skills are pretty good might as well challenge my self. i think dave has done supercharger work on v6s since he posted a wanted ad for a test car. anyone done this before? any ideas?
thanks guy, Anthony
thanks guy, Anthony
Car: 1985 Firebird
Engine: 3.1L (planning for a turbo)
Re: school project for v6, startin to get ideas need some help guys!
the M90 used the thunderbird supercoupe would be the charger of choice for ease of install, its got a discharge pipe. just be a matter of making a bracket and finding a belt the right size to run it all. shouldent be that hard at all..
a remote mount triple turbo with a supercharger if you want a challenge (I just made that up, major props to any one that can pull that off :lol)
Cant be that bad, guy on latteral-g.net managed to fit a LS1 in a 57 Chevy and then gave it 8 turbos for ***** and giggles
Look on the V6 board for tips on the V6, several of them are running boost
Car: 1985 Firebird
I've seen that 57 on the net, dude had way to much time on his hands.. to be runng 8 turbos it wasent all that powerful (i think a little over 1000HP..2 turbos can do that.) quite a few of the V6 guys run boost, most are going with turbos though. eiser to setup and the parts are reasonable for the power you gain.. swaping to a FWD top end is becoming quite popular too (I've got a V6 bird, so I spend 90% of my time in the V6 section.)
Like this...
I don't have any use for it. It's got a fresh rebuild and has been ported. As is it's good for over 200hp, and more with a smaller pulley. Since I will now have a mock-up engine, I was thinking of making a kit to bolt the M90 to the 60*'s (I have a CNC shop and welding equipment). This is from a GM, the only difference between this and the Supercoup model is the way the TB's mount (oval back on the Ford model, instead of the round TB mount).
