Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
How wide is a 3rd gen axel?
Old Sep 29, 2007 | 04:22 PM
SSnthe10s's Avatar
Car: 1992 Firebird
Engine: 350 with vortec heads
anyone? and also how wide is a 4th gen axel. I wanna put a wider axel in my car to accommodate the ZR1 wheels in the back with out running spacers. Plus i have a wider 8.5" ten bolt.
thanks guys
Old Sep 29, 2007 | 04:37 PM
Re: How wide is a 3rd gen axel?
3rd gen = ~ 61¼"
4th gen = ~ 64¾"
Getting the 8½" 10-bolt in there is DEFINITELY going to require a certain amount of fab work.
Old Sep 29, 2007 | 05:31 PM
SSnthe10s's Avatar
Car: 1992 Firebird
3rd gen = ~ 61¼"
4th gen = ~ 64¾"
yes i know this will take some fab work. shouldnt be to bad. I can weld like a roll of dimes. and these lengths were taken axle flange to axle flange?
Old Sep 30, 2007 | 12:07 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
2nd gen camaros apparently have the right width 8.5" 10 bolt, if that's what you've got?
Other 8.5" 10 bolts... anyones guess, but let us know what you've got it from, and if it'll work.
Welding the tubes for LCA's, panhard, shock, and springs are fairly straightforward. Welding the pumpkin (cast iron) for the TA is what makes most people shudder
Old Sep 30, 2007 | 01:48 PM
SSnthe10s's Avatar
Car: 1992 Firebird
I have 2 8.5" rears. one out of a 01 s10 zr2 witch is about 64" wide and has disc brakes. And i have one out of our 70' camaro with 3.73s and moser axles but im not exactlu sure how wide it is. And im a welder for a living I think i could tig weld the TQ arm mount to the pumpkin using nickel rod. Thats the best stuff to use on cast iorn. But i think i wanna use the s10 rear end because it is almost as wide as the 4th gen rear and i wanna run my ZR1 wheels.
ex-x-fire
Jan 12, 2024 01:58 PM
Warlocksirix
Sep 3, 2015 12:26 PM
Bstrang6
Brakes
Aug 24, 2015 06:45 AM
tricky1
Aug 23, 2015 01:17 PM
reiderz iroc
Aug 13, 2015 04:57 PM
