Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
HELP! Stainless Steel Braided Fuel lines.
Old Oct 31, 2007 | 01:38 AM
86irocu's Avatar
Car: 1986 Iroc-Z
Axle/Gears: 3.73 posi
I'm currently doing a swap from a cc qjet to a 305 TPI and the fuel lines are on the wrong side. So I decided to use stainless braided line to route the fuel lines to the drivers side. I plan on routing the lines on the fire wall.
My question is how do you use the hard line adapter fitting?? The fittin i have is just like this one on jegs: http://www.jegs.com/webapp/wcs/store...56885_-1_10019
I'm using -6 an line and fittings for the return and the pressured line. The pressured line is 3/8" and the return line is 5/16". That fitting should work for both right?? I cant seem to figure out how to use the fitting. What do I need to do to the hard line in order get the fitting to work?
Thanks.
Old Oct 31, 2007 | 12:15 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
Re: HELP! Stainless Steel Braided Fuel lines.
cut off the end of the stock fitting then slide the factory line into that tube and tighten, it's a basic compression fitting. IMO, I would just get some adapter fittings to work with your factory fittings and do it that way. You don't need to run the line along the firewall and that is not the safest way either. Just run the single line over the valve cover and into a 90' fitting on the dual feed line into your holley carb.
Old Oct 31, 2007 | 07:07 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
im using on of those fittings, just a basic compression fitting, it worked well, depends on the condition of you existing hard lines, they need to be clean, mine are new.
they dont make one for the 5/16 line, just the 3/8. To use the 5/16 you would probably have to flare the pipe and use a AN flare nut.
Frozer!!!
Jan 19, 2024 04:55 PM
MustangBeater20
Carburetors
Aug 21, 2015 02:42 PM
Dialed_In
Aug 20, 2015 01:45 PM
AkDrifted
Aug 17, 2015 07:45 PM
