Second Gen Firebird Spoiler
Car: 1985 Camaro/89 Merkur XR4Ti
Engine: 5.0 305 LG4/2.3 Turbo (180hp/205tq)
Transmission: TH700R4 with Shift Improver Kit/T-9
Axle/Gears: 3.42LT1 Rear/3.64
Hey, I was wondering if anyone ever tried making, or modifying a second gen firebird spoiler to fit a third gen firebird. The spoiler Im thinking of is the one in this picture, http://www.firebirdtransamparts.com/...everforget.jpg
Car: 80 SE/TTA;88 T/A GTA;86 T/A
Engine: 4.9L Turbo; LT1; empty
Transmission: TH350; T56; empty
Axle/Gears: 3:23 disk; 4:10 disk ; 3.42 disk
Re: Second Gen Firebird Spoiler
a lot of work, but i think it would be well worth it, curious if it would fit at all with the body lines...
My original idea was a thirdgen camaro spoiler with the side pieces modified to go straight down instead of at an angle, that might prove to be easier.
poor cars in that pic
, i accept donations of heavy pieces of metal that were once cars :-D hehe, newayz, yea 2nd gen firebird on a third might work out with the same principle in headlights, probably a lot of fabrication but non the less possible. I don't know if the lip angle would work as it should. I don't know, anyone good on photoshop possibly willing to play with this idea if noone has done it in real life?!
, i accept donations of heavy pieces of metal that were once cars :-D hehe, newayz, yea 2nd gen firebird on a third might work out with the same principle in headlights, probably a lot of fabrication but non the less possible. I don't know if the lip angle would work as it should. I don't know, anyone good on photoshop possibly willing to play with this idea if noone has done it in real life?! Banned
Car: 1989 T/A
Engine: PROCHARGED LB9
Transmission: FB BUILT 700r4 2200 stall
Axle/Gears: 10 BOLT EATON 3:73 POSI
UD BE BETTER OFF BUYING A CAMARO 3" SPOILER FROM HAWKS, THAT WOULD REQUIRE MINIMUM MODIFICATION. AND IT LOOK THE SAME. AND U CAN EVEN PUT THE 2ND GEN GRAPHIC ON THE BACK, THAT WOULD LOOK SWEET.
the rear 1/4s are wider on a bird by like 1/2-1 full inch on top, the camaro is like an inch wide from body to tip, firebird starts off with an inch but widens to like an inch and a half by the time you get to the tail lights i believe, i may be wrong but thats what i've been told in the past. but either way it would be a starting point...just it might look wierd with that angle of spoiler going down the side with no lights there like they go beside on the camaros
Make one. Here's a custom 70's-ish style spoiler that was made for a 3rdgen camaro: https://www.thirdgen.org/forums/auto...il#post2244542
Car: 1987 Firebird
Engine: 355
Search Special Appearance Package, it was kind of like the low rise camaro spoiler option. Both offered in 88 by the dealer i beleive.
They basically took a camaro spoiler, and made it fit a bird. It might be too short for your liking, but itll give you an idea of the lines.
The package had side spats to go with it as well.
colton_carlson
Mar 8, 2019 12:21 PM
AkDrifted
Aug 17, 2015 07:45 PM
