Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
nose peice body
Old Mar 19, 2008 | 02:14 PM
Rva's Avatar
Rva
Car: 1984 z28 camaro
nose peice body
can you take a nose peice body kit from like a 86 and put it on a 84 because i think the body kit on the front of my camaro is ugly but i like the ones on the 86's and if so how much would it cost
Old Mar 19, 2008 | 07:57 PM
VonKaiser's Avatar
Car: 13 Ford Focus SE / 90 Camaro RS
Engine: 122 I4 / 305 V8
Transmission: DCT / 700R4
Axle/Gears: 3.895 / 2.73
Re: nose peice body
The answer is yes, you can put any 3rd gen Camaro nose on any year. the cost is just the same as if you were buying it normally. Usually $50-150 depending on condition I guess.
Old Mar 19, 2008 | 09:51 PM
Rva's Avatar
Rva
Re: nose peice body
thanks the 86 nose will look so much better on my car
Old Apr 22, 2008 | 02:23 AM
smwellma's Avatar
Car: 1984 Camaro Z28 H.O.
Engine: 305 H.O. L69
Transmission: TH700r4
Re: nose peice body
In fact you cant put just any front clip off a third gen, on your camaro. It just so happens that if your 86 is an irocz with a body kit that differs from lets say an 84 z28, they wont line up. I had this issue when i bought a 87 irocz, when i tried putting it on my 84 z28.
Old Apr 22, 2008 | 08:01 AM
Rva's Avatar
Rva
Re: nose peice body
im just trying to put like a 86 rs chinpeice
Old Apr 24, 2008 | 06:56 AM
87tpi350,6spd's Avatar
Car: 87 Trans am
Engine: 350tpi
Transmission: 6spd
Axle/Gears: 4.10
Re: nose peice body
The ground efects are different sizes I belive there are 3 different ones. You can bolt any of them up but the lines down the side of the car won't line up unless you do the whole car. if your not to concerned with it you could just do the front and not worry about it but if you are paying atention when you look at the side of the car it will be noticable.
Hotrodboba400
Dec 10, 2019 07:07 PM
83 Crossfire TA
Jan 3, 2016 01:26 PM
Silver Spear
South East Region
18
Dec 4, 2015 09:59 PM
Kenwood
Sep 4, 2015 05:50 PM
Formula_88AE
Sep 3, 2015 01:47 PM
