Another CAI idea
Car: 92 Camaro
Engine: Dart SHP 406 HSR, LE heads
Transmission: Performabuilt Level 2, Vig 3200
Axle/Gears: S60 373
Another CAI idea
I was looking through gmhightechperformance.com and I saw the article for the Magnum TPI....Come to find out...its the big brother of my car! Its a 396 276hr AFR 195 SLP 1 3/4 dual cat. Only difference is it has the MINI ram and I have HSR. Well I was reading about the CAI they made (http://www.gmhightechperformance.com...ipe/index.html)
I dont want to pay the money they did for it so I thought about getting 4 inch piping from exhaust shop or summit, getting a bigger Cone filter, hose clamps and 4 inch hose and having at it.
SUM-640040-$18 for 4 feet of tubing 4 inch pipe
Cant find hoses but clamps are 5 bucks
KNN-RF-1015- $42 Air Filter
WLK-41367- $34 90* mandrel bend 4 inch pipe
anybody think this will be worth it or am i just out there in left field?
Car: 92 Camaro
Axle/Gears: S60 373
Re: Another CAI idea
Is the idea that bad? Senior Member
Car: 1987 IROC
Engine: Vortec 350 TPI
Transmission: 7004r
Only downfall would perhaps be the weight difference between plastic and steel. I say go for it and show us how it looks!
Car: 1988 Camaro
Engine: 383 Stroker
Transmission: Probuilt 700 R4
I only wished there was a way to do it without relocating the battery to the trunk!
Car: 92 Camaro
Axle/Gears: S60 373
MY battery is on the drivers side....my intake comes in from the passeger
Car: 92 Camaro
Axle/Gears: S60 373
got the parts in today...will post pics when done
Car: 1987 Trans Am
Engine: 355ci L98 soon to be turbo'd
Axle/Gears: 2.73 posi
If my car wasn't MAF, I would have done this a long time ago, but right now I have my CAI exactly as they did it, but with 3in piping...
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
It should work ok. I did mine with 3"PVC pipe in the same location as that article. the only problem I had was getting a rubber coupler that would fit the PVC pipe and the intake on the 3.1. I ended up using the stock piece that goes from the plenum's intake over to that corner. I'm still experimenting though.
4" pipe might be a little too big to fit down past the evap can though. Mine just barely squeezes in over there.
Car: 04 Jetta
Engine: 1.8t AWP
Transmission: 5spd
Car: 1987 Trans Am
you know, know that I think about it, I might just do a 4" tubing up to the CAI, doubt I'll see much of a difference, but I'm sure it couldn't hurt... I enlarged the hole pretty well...
Car: 92 Camaro
Axle/Gears: S60 373
Finally!!! the weather cleared up and took me a few shots of Bacardi and half a pack of smokes and some cuts on my fingers, but its in! Doesnt look very pretty, but it works! I went for a test drive and it doesnt hit any belts and doesnt move. I only wish I wouldnt have burnt the drill motor up.....I wanted the whole bottom piece to be gone. But hey I fit that filter about 3/4 the way down it. I had to cut the 45* pipe though. For some reason, I went with one 90* pipe and one 45* pipe
If I wouldve ordered two 90*....that filter would defiantly be underneath the engine compartment. But until I wanna cut my hands up again, the 4.5" hole should do just fine. ill post pics up when I get batteries for the camera.
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Or you could go this way:
With the filter under the car.
Car: 92 Camaro
Axle/Gears: S60 373
that was my initial intention, but for some odd reason I ordered one 90* pipe and one 45* pipe. I'm still smacking myself for doing that. Your setup looks ALOT cleaner than mine. Is it 3" or 4" Dyno Don?
Last edited by 89formula350b2l; May 15, 2008 at 06:58 PM. Reason: bc i have fat fingers!!
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
nice intake setup! i just wish i could make one for my MAF
But its been said before the stock MAF will be the limiter. i wish it was bigger
But its been said before the stock MAF will be the limiter. i wish it was bigger Joined: Jul 2003
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
j/k
Car: 89 Iroc-z
Transmission: TH400
i dont think those will work for our cars without alot of programming and modifications, but they look nice
^ Check it out, Click here....
Edit: They moved the video for it, lemme see if I can find the new link.....
Edit: Here it is, Click here....
Car: 89 Iroc-z
Transmission: TH400
interesting..i wonder how hard it would be to calibrate it and if they have a downloadable calibration for it for our ecms?
Car: 92 Camaro
Axle/Gears: S60 373
You can make your own pretty cheap but i will admit, it is purdy Don
