Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
85 firebird headlight options
Old May 6, 2008 | 06:53 AM
mellis09's Avatar
are there any other options as a headlight other than the flip open for the firebirds?
i saw this one http://www.cardomain.com/ride/715283/12 which seems reasonable
i saw these but i havent seen any for a thirdgen http://cgi.ebay.com/ebaymotors/93-97...ayphotohosting
Old May 6, 2008 | 02:35 PM
adriancamaro's Avatar
Car: 1992 Camaro RS
Engine: 305 TBI
Transmission: T5 WC
Re: 85 firebird headlight options
well, i can't open the links (my high school blocked the websites). but i know there is a thread on here where a guy put the camaro fixed style headlights on the firebird. the whole bumper has to be replaced. i don't know if he just used a camaro bumper or not (i would assume so, it would be easier). personally i don't like the look, but i will give credit where credit is due.
Old May 6, 2008 | 02:54 PM
campin1983's Avatar
Car: 1984 Camaro 'Vert
Hmm, maybe its just me, but I'm a bit queasy about the ebay lighting solution.
Why are you wanting to get away from flip ups? Bad motor or just want to go with a different look?
if your willing to do a little work, I'm sure you could swap out the front bumper and headlight assembly from a camaro and go with that setup. I'd trust it more than ebay headlights anyways.
Old May 8, 2008 | 10:05 AM
mellis09's Avatar
im looking for a different look.. want to switch it up a little.. the ebay lights were just an example of something i would want to do to my bird.. how would i go about converting to camaro headlights.. ive seen it dont i just dont remember where..
Old May 8, 2008 | 10:46 AM
campin1983's Avatar
That'd be fairly easy really. You'd just remove all the firebird specific stuff on the front (headlights, front bumper, turn signals) so that your just down to the mounting point on the front end, and the wires. Then go take all of that stuff off a camaro and transplant. Both are F-bodies, so assuming you take off the whole front bumper assembly and headlights, I'd assume the camaro stuff would mount right back on.
Old May 9, 2008 | 09:36 AM
mellis09's Avatar
are you saying switch over to a camaro front bumper?
Old May 10, 2008 | 03:27 AM
HCR13's Avatar
Car: 1987 Trans Am
Engine: 355ci L98 soon to be turbo'd
Axle/Gears: 2.73 posi
you should just sell the Firebird and buy a Camaro... The Camaro bumper will not fit a Firebird because the angles are different. The Firebird's front end is much more scooped than the Camaro. When I first got my Trans Am I wasn't big on the flip up lights, but now I love them... there's nothing cooler than turning your car on at night pulling out and turning the lights on and just see the headlight beams flip out straight ahead... Do a search, many people have done pop-up-delete headlights...
Old May 10, 2008 | 07:58 AM
campin1983's Avatar
If you want Camaro style headlights, yes. Otherwise, no.
1992 Trans Am
May 10, 2023 07:19 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
Adamki2000
Brakes
24
Dec 20, 2015 10:40 PM
DiabolicalRS
Aug 26, 2015 07:35 AM
pigpete
Exterior Parts Wanted
Aug 15, 2015 07:56 AM
