Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Motor Mounts
Old May 27, 2008 | 06:51 PM
bwtaylor84's Avatar
Car: Camaro
Engine: 350 .40 over
Transmission: TH400 TCI
Motor Mounts
Anyone ever changed motor mounts on 84 H.O The bolts that hold them in place have nuts on the back of them and the nuts are in the crossmember!
Old May 27, 2008 | 06:55 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Motor Mounts
they sure are.
you can get to them through the a-arm pockets, i did it with the suspension still in the car, but its a LOT easier to do it with the a-arm off.
Old May 27, 2008 | 06:58 PM
bwtaylor84's Avatar
Car: Camaro
Re: Motor Mounts
I found it to be somewhat crazy I thought I would need some special tool thanks alot! any tricks to recomend
Old May 27, 2008 | 09:18 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Re: Motor Mounts
yup, take the a-arms off. the easiest way to do it.
other than that, you need 3/8 extension, crows-foot wrench and a swivel joint. You can get to the nuts through the a-arms mount holes, and i think there are holes in the k-member too, but they are not all very helpful. You can see all the nuts, but you have to be a contortion artist. 1 person under the car, one on top holding a wrench on the bolt so it doesn't spin. have fun! I assume you have the motor out?
oh, and the nuts have washers on them too.
E Rod
Aug 28, 2015 05:17 AM
Wesly_66
Aug 26, 2015 09:55 PM
Elliswon
Aug 10, 2015 12:33 PM
NBrehm
Aug 5, 2015 07:57 PM
