Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
cup holders
Old May 31, 2008 | 12:47 AM
89camaroRS6's Avatar
cup holders
i am trying to install the cupholder fabrication mentioned and i went to take of the shift **** and the clip that is supposed to pull out went in and i cant do anything and i need help on what i need to do to get the **** off any help would be great thanx
Old Jun 1, 2008 | 04:11 PM
87GTAj's Avatar
Car: 87 Trans Am GTA
Engine: 5.7L TPI
Re: cup holders
Are you referring to the clip that retains the **** and faces the front of the car (because there is a second one for the button IIRC)? If so, mine was pushed in pretty far when I had to remove it, so I cut the leather slightly larger around where the clip is, and used a thin flat head screwdriver and very small needle nose pliers and it came right out.
Old Jun 2, 2008 | 06:34 PM
rough's Avatar
Car: 88 Camaro
Engine: 305 TBI
Transmission: 700-R4
Re: cup holders
screwdriver and needle nose ftw !
Fanatic1074
Oct 3, 2022 05:57 AM
75bike
Sep 20, 2015 09:37 PM
IROCZDAVE (88-L98)
Sep 17, 2015 07:43 AM
gta892000
Sep 16, 2015 12:37 AM
