Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
lca relocation brackets
Old Jun 25, 2008 | 09:40 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
does anyone still have the drawing still. I just can't find the cad drawing I had of them
Old Jun 27, 2008 | 06:00 AM
Engine: ls1, LB9
Re: lca relocation brackets
no one has this still?
Old Jun 27, 2008 | 09:52 PM
TZFBird's Avatar
Car: 1988 Firebird, 2000 GTP
Engine: 327
Axle/Gears: 9" posi, 4.11
Let me know if you get a hold of it. I had it at one time, but have also lost it.
Old Jun 27, 2008 | 10:35 PM
Stephen's Avatar
Car: 87 GTA
Not in CAD, but I scanned mine in & took measurements.
Hmmmm....
For the 2 holes where the LCA actually mounts, I see I need measurements from the leading edge too.
One dimension measurement is no good. Need X/Y measurements to properly locate them.
EDIT: I measured them & edited my pic.
Last edited by Stephen; Jun 27, 2008 at 11:17 PM. Reason: LCA measurements fixed in the pic...
Old Jun 28, 2008 | 08:22 AM
Tobias05's Avatar
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
uh oh, steve's gonna be upset, haha...
Old Jun 28, 2008 | 09:43 AM
Engine: ls1, LB9
with the dozens of knock offs It could be anyones's
Old Jun 28, 2008 | 10:02 AM
Stephen's Avatar
Car: 87 GTA
Why would I be upset, at myself? I go by Steve or Stephen....Either works for me.
Old Jul 2, 2008 | 06:15 AM
3rdgenmaro's Avatar
Car: 88 IROC
Engine: 97 5.7 Vortec LT4 hotcam
Transmission: 700 r4
Im still curious, I know the reason for relocation brackets, but are they needed for a stock ride height car?
Last edited by 3rdgenmaro; Jul 2, 2008 at 06:15 AM. Reason: I cant type this early in the morning without mistakes
Old Jul 2, 2008 | 09:18 AM
Stephen's Avatar
Car: 87 GTA
Needed? No. Will they help? Yes. Also, as the rear of a car squats, effectively lowering the car on launch, you lose the angle. Having your LCA relocated lower, will allow them to retain an effective level longer, as the car squats on launch.
Old Jul 2, 2008 | 01:05 PM
Black82Z's Avatar
The reason for LCA relocation brackets is to change the instant center of the system and thus the anti squat %.
Lowered or not, doesn't matter. It is for the suspension dynamics part of it
Old Jul 2, 2008 | 02:12 PM
3rdgenmaro's Avatar
Car: 88 IROC
gotcha. thanks. I knew that they were very beneficial to lowered cars, but I was under the assumption that they mearly changed a lowered car back to the stock angle. Thanks again.
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
jovibuilt
Exterior Parts Wanted
Oct 18, 2015 08:12 PM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
armybyrd
Sep 26, 2015 03:37 PM
