Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
RUST!!
Old Aug 17, 2008 | 10:57 PM
Mr1983z28's Avatar
Car: 1978 monte ss and 1992 camaro z28
Engine: beat me and ill tell ya
Transmission: th400
Axle/Gears: 373
RUST!!
ok so i just bought a 1983 z28, i have completley gutted it and came across alot of rust, somone before me has already patched up the floor but they didnt get rid of the old rust, therefore the cancer was still there just slowed down a bit, now i have the driverside rear seat area all cut out and some of the rear fender, im wonderin what im gonna have to do to re-enforce the lower control arm plate so i can get this thing goin, heres some pics of what im workin with.
Last edited by Mr1983z28; Aug 17, 2008 at 11:09 PM. Reason: pictures didnt show up
Old Aug 20, 2008 | 04:49 PM
sleepsinshed's Avatar
Car: 1988 IROC
Axle/Gears: 3:27 9-bolt
Re: RUST!!
Wow, I don't feel so discouraged with my rust bucket anymore. I don't think flat sheet steel will be enough unless you strengthen it by adding "ribs" (don't know the correct term) like the factory did.
Old Aug 20, 2008 | 11:33 PM
Mr1983z28's Avatar
Transmission: th400
Axle/Gears: 373
Re: RUST!!
yea i know for a fact sheet metal wont cure my problem, but explain to me what u mean by ribs... i mean its pretty solid but i want to enforce the problem better than factory, so that i dont ever have to worry about it ya know... and i dont want to go out of my way and do work if i dont have to lol
Old Aug 21, 2008 | 02:34 PM
camaro_guy24's Avatar
Car: 91 Firebird w/ L03
Engine: LT-1 Swap still in the works
Axle/Gears: 10 bolt w/ 2.73 (Needs 3.42 w/posi)
Re: RUST!!
I would say after you get your sub-frame connectors in you shouldn't have to worry about it
Old Dec 16, 2009 | 08:53 PM
Mr1983z28's Avatar
Transmission: th400
Axle/Gears: 373
Re: RUST!!
ok so i said **** it and found another body, only this one is completely stripped, im talkin rolling chassis, not even wiring on the thing. heres some pics to give a lil update
Attached Thumbnails RUST!!-92z28front.jpg   RUST!!-92z28left.jpg   RUST!!-92z28rear.jpg
Old Dec 16, 2009 | 09:09 PM
Mr1983z28's Avatar
Transmission: th400
Axle/Gears: 373
Re: RUST!!
2 more pics
Old Dec 20, 2009 | 01:03 PM
92 Camaro's Avatar
Car: 1992 Camaro RS, 66 Mustang, 78 t/a
Engine: 5.0 TBI, 289, 400
Transmission: 700R4, C4, th350
Re: RUST!!
now you don't have an 83 z28 anymore do you
Old Dec 25, 2009 | 06:57 PM
montesscamaro's Avatar
Car: 84 monte carlo ss 85 camaro z28
Engine: 350/350vortec
Transmission: turbo 350/700r4
Axle/Gears: stock posi
Re: RUST!!
good job on ditching fred flintstones camaro hahaha good luck on the new project :]
Old Dec 25, 2009 | 07:23 PM
Mr1983z28's Avatar
Transmission: th400
Axle/Gears: 373
Re: RUST!!
nope shes a 1992 Z, and thanks for the good luck on this project lol i got all the time in the world just no money here in michigan haha. right now i got a motor in the shop gettin punched over, gonna put her in my 78 monte and whats in the monte is goin in the camaro. the monte runs 11.62's and that motor in the camaro is gona sh*t n get, we'll see this spring!
Old Dec 25, 2009 | 08:14 PM
Re: RUST!!
cant wait good luck! looks like it pretty solid
Old Dec 25, 2009 | 08:42 PM
Mr1983z28's Avatar
Transmission: th400
Axle/Gears: 373
Re: RUST!!
yea me either, the only rust its got is on the pass rear fender and its only surface about the size of a quarter, where u from? maybe we can line em up this summer lol
Old Dec 25, 2009 | 10:16 PM
Re: RUST!!
i live in southwest pa i also have a 84 monte ss and my 85 camaro project "91 92 z28 clone" my monte probably lose but my camaro with a little more bolt ons and modding im sure it will freakin fly. i wish it was posi thats the only thing thats gonna kill it a the strip im going to have to solve that issue i might just get a different rearend.
Old Dec 25, 2009 | 10:31 PM
Mr1983z28's Avatar
Transmission: th400
Axle/Gears: 373
Re: RUST!!
just weld up the rear spool! take the cover off, pull out the rear gear, weld in the side spyder gears, take it to a welding shop if ya have to , leave the top n bottom spyders out, throw em away lol put it back in and u now have a posi rear gear... not the professional way of goin about it but it does work like a charm and make sure the weld is a good bead or u can blow out the housing and then u gotta replace the rear end lol tmrw ill hit my storage unit and take a few pics of my 4.10 spool thats welded up
Old Dec 26, 2009 | 09:09 AM
Re: RUST!!
i heard of bad things happening from welding a rearend i did it on a pulling tractor but i dont want to on my car. plus i know where i can get a good low milage posi rearend for probably 150 175 range and when i switch them i can detail and clean the new one up with all new stuff
RyanJB
Members Firebirds
39
Nov 20, 2018 03:30 PM
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
Fireslash
Apr 11, 2016 06:43 PM
FueledSoul
Sep 30, 2015 09:18 PM
tcflint
Sep 27, 2015 05:58 PM
