Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
shaved door kit
Old Aug 30, 2008 | 04:29 PM
liveyourself's Avatar
Car: 1986 firebird 2.8l v
Engine: 2.8l v6
Transmission: automatic =[ looking for 350 or 305
shaved door kit
can some 1 give me a link to a cheep 1 that works i already have a alarm sys in my car
Old Aug 30, 2008 | 05:37 PM
TZFBird's Avatar
Car: 1988 Firebird, 2000 GTP
Engine: 327
Axle/Gears: 9" posi, 4.11
Re: shaved door kit
$150
http://www.speedwaymotors.com/p/2425...?itemNo=shaved
$200
http://www.speedwaymotors.com/p/7417...?itemNo=shaved
Not sure about quality, but it seems to come with everything you need. Seeing as how they are 40lb solenoids I think the only problem you could run into is that they try pulling themselves off the door. If you keep looking on the site, they have some other kits as well that look a bit cheaper.
Old Aug 31, 2008 | 09:13 AM
acadburn's Avatar
Car: 1989 Camaro RS
Engine: 305 V8
Re: shaved door kit
http://cgi.ebay.com/ebaymotors/50LB-...spagenameZWDVW
this is the kit i bought for my grand prix.... I know a grand prix but it worked relly well although always shave the doors after you have the kit installed for a while
trust me if your dors are not adjusted correctly its not hard to lock yourself out. also if you live somewere where the climate really can change from say 100 degrees above to freezing a few months later make sure u run the car with the kit both times before you finish shaving the doors
Terrell351
Jun 13, 2021 01:13 PM
1Aauto
Sponsored Vendors
Aug 26, 2015 02:14 PM
Out-Cast
Aug 23, 2015 06:33 AM
madsv1000
Aug 20, 2015 06:45 AM
BlackTopKing
Aug 19, 2015 12:13 PM
