"Double hump" transmission crossmember
Just got finished with this last night. Had to build a new trans crossmember as I'm putting in Hawk's long tube headers with the rebuild this time. I didn't like the way the Hawk's y-pipe went under the factory crossmember so I made a new one to keep from losing ground clearance.
Made it out of a piece of 1/4" plate and 1"x1" tubing for the actual trans mount plate, the 2 "humps" are cut from 1/4" x 5" angle, and the 2 frame plates are made from 1/4" cold roll steel. Ended up taking a lot longer to make than I expected or planned, but it turned out well.
And the weld on the left, it's just the shadows, it doesn't really look that bad
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: "Double hump" transmission crossmember
Similar idea to a g-body double hump crossmember but I've never seen anyone do it for a third gen f-body.
Here's the link. There isn't one listed for third gens
http://www.transmissioncenter.net/gf..._.htm#f%20body
Car: '91 TA vert
Engine: turboLSx
Nice. Good job. Reminds me of the Skulte designd one.
http://www.skulte.com/product_info.p...products_id/83
I've been using a similar one built by the member "drews" for quite awhile. Made it really easy to put my LTs in.
Another members mounted up. Don't recall whose car this was though.
Car: 87 IROC L98
I like that Skulte design. It puts the angle iron ends pointing upwards away from the pipes but the angle has been flattened out to fit better. I may incorporate that design in my new crossmember. Dual 4" pipes don't leave a lot of room. My pipes currently run under a home made crossmember but I don't like the design and will redo it later this winter when I yank the tranny out.
Car: 91 Firebird Formula
Engine: 383
Transmission: built 700r4
Axle/Gears: 4.11, 9inch
what about doing this with a 700r4 all it shows from skulte is for a t-56 swap
whats the difference in tranny mounts?
Car: 92 Z28
Engine: Boosted LSX
Heres one someone did from here and I powder coated it for him. I forget who it was.
http://www.cecoatings.com/images/coa...rossmember.jpg
http://www.cecoatings.com/images/coa...ossmember1.jpg
http://www.cecoatings.com/images/coa...ossmember2.jpg
http://www.cecoatings.com/images/coa...ossmember3.jpg
http://www.cecoatings.com/images/coa...ossmember4.jpg
http://www.cecoatings.com/images/coa...RQarmmount.jpg
The one the OP posted doesn't look near as strong as the other ones . Those ones are boxed, although the last one only partially. The first one is just flat stock. I don't know if it's strong enough or not, but it's not as strong as the others.
Mathius
Mathius
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
The only thing I see with the one pictured in post 7 is you loose some ground clearance compared to the others. Otherwise very well made.
TOMcat GTA
Sep 15, 2015 09:31 AM
