Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
will these wheels fit with no problem
Old Jan 5, 2009 | 06:32 PM
weswisehart's Avatar
Car: 91 RS T-top
Axle/Gears: 3:42 fourth gen disk brake
Im looking to buy some 17 X 8.5 (front) and 17 X 9.5 (rear). My question is would these wheels fit with little or no problem? Also I am considering putting 18 X 9.5 (rear). What are your opinons and would this work? 17s front 18s rear or should I stay with 17s all around?
Old Jan 5, 2009 | 10:05 PM
camarozz383's Avatar
Car: 1989 camaro rs
Engine: ls 5.3 carb
Transmission: t56 six speed
Axle/Gears: 3:73
Re: will these wheels fit with no problem
hey man i have 18x9 front and rear with 275/35-18" front and 295/35-18" rear, hope this helps.
Old Jan 5, 2009 | 10:25 PM
Car: 91 RS T-top
sweet thanks
Old Jan 31, 2009 | 10:27 PM
500+hpta's Avatar
Car: 1984 trans am
Transmission: 350
IT REALY DEPENDS ON YOUR BACK SPACING. I AM RUNNING 18"X 10.5" 8" BACKSPACING CORVETTE C6 WHEELS ON MY 84. I HAD TO USE 2" SPACERS AND A BFH TO GET THEM TO FIT BUT THEY STUCK OUT THE SIDES ABOUT 1/2" AND WERE PUT IN A BIND WHEN I HAD SUSPENSION TRAVEL AND THE TIRES HIT THE LIP AND THE INSIDE OF THE WELL. I FINALLY STARTED DOING A MINI TUB THIS WEEK AND AM ALMOST FINISHED. I HAVE 40+ PICS FOR THE PASSANGER SIDE ALONE ON HOW TO DO IT IF PEOPLE WOULD LIKE TO SEE. LET ME KNOW
Omega
Oct 1, 2015 02:20 PM
kah992
Aug 19, 2015 02:55 PM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
greeny
Wheels and Tires
Aug 12, 2015 03:55 PM
Fronzizzle
Aug 9, 2015 01:15 PM
