Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
welded doors?
Old Mar 18, 2009 | 07:52 PM
jerryd87's Avatar
welded doors?
is there a class that allows this? would like to weld em so i can get rid of all the brackets,bracing and everything and just use window nets but idk if this is allowed
Old Mar 18, 2009 | 09:34 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: welded doors?
Drag cars require doors that open and windows need to be closed. If you want an open body car, you can't do it in a door car. You need to run an altered or dragster. Even a convertible needs the top up and windows closed.
About the only "class" that requires welded doors is oval racing because of all the bumping and grinding they do, they don't want the doors to open when hit.
Veaceonee
Sep 29, 2016 08:15 PM
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
Buggy Disaster
Sep 17, 2015 05:12 PM
1Aauto
Sponsored Vendors
Sep 10, 2015 02:02 PM
NiG
Sep 7, 2015 11:25 PM
