cam bearing removal tool
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: cam bearing removal tool
Do you own a lathe?
These need to be pretty precise to work... I have the summit version, and it was $60. I'd be hard pressed to make one for that price... If I bought the material, I might be able to get it cheaper then that, but if I were to break/wear out one lathe bit, i'd be over the cost. Not worth it to me.
Car: 1982 Trans-Am
ah, in that case, it's a brutally simple tool.
I have mine in my garage, and a digital calipers. I can measure it for you if needed. I'll give it a day for someone else to reply if they can find it off google....
If you buy a set of cam bearings, you can measure those to find out...
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
The journals of a SBC and most other blocks are different sizes in the block. The installation/removal tool is basically a press to allow you to press in and out the cam bearings.
Here's the instructions with OD dimensions from the summit site. The ID size is the journal of the camshaft. The Summit tool is cheap because it will only do SBC bearings. The universal kits are $200+
http://static.summitracing.com/globa...sum-900130.pdf
Car: Used to drive a camaro
86, don't mean to hijack too bad but I'm from a tool&die background as well. Got started at 21 back in 98' and recently left the field. Illinois was a MAJOR region for me for motorola, nokia, a few closure molders, etc. Good times. These guys are right though, just spend the 60 bux and buy the tool. Use your maching skill and desire on making parts for our cars you think we might all need, i.e. a throttle body spacer that you can tap (NPT) or mill for fuel injectors. I just designed and made one myself for my setup. WORKS sweet! I can port NOS or fuel injectors in if need be.
Car: 1986 Z28
Engine: 305 for Now
Ya I think I'm gonna just buy it. I was thinking about making one of those 1 inch spacer for under my carb like they sell. Theres not alot of tool& die stuff out there anymore its a dying trade.
ambainb
Apr 25, 2016 09:21 PM
Dialed_In
Aug 20, 2015 01:45 PM
