Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Sub frames (final design and build)
Old May 13, 2009 | 11:11 PM
  #51
FueledSoul's Avatar
Car: 84 camaro, 88 trans am, 98 camaro
Engine: Modded , stock, LSX modded
Transmission: 700r4, 700r4, t-56
Axle/Gears: 327, 308, 373
Re: Sub frames (final design and build)
So i decided to now go with 2x1" tubing for the inners and centers. I will have to pick some more steel up this week. I also completely changed the center tube design. My dad had a great idea and i ran with it. It looks great on paper and at the top of the thread in MS paint. but under the car is a different story once you see how the steels going to be ran, there's to much angle in the center tubes. i will post pics later after im done building the inner tubes.
Old May 13, 2009 | 11:12 PM
  #52
Ca[maro]88's Avatar
Car: 1988 Camaro Sport Coupe
Engine: 5.0 305 Carb'd
id just go with the 2X1 tubing, you have plenty of strength in the square tubing. if its not enough, then just get 11 gauge 2X1 tubing instead of the 14 gauge 2X1.5 that would make up for toughness id reckon.
Old May 13, 2009 | 11:13 PM
  #53
Ca[maro]88's Avatar
okay maybe not lol. looks like i was a minute to late ha.
Old May 19, 2009 | 02:41 PM
  #54
BPWilliams's Avatar
When I built mine I knew that they were going to tie into the full roll cage so I did not go across the car like you are planning. I used 2X3" box and needed the ground clearance so I stuffed them up nice and tight.
Attached Thumbnails Sub frames (final design and build)-sm_camaro56-003.jpg   Sub frames (final design and build)-sm_camaro56-006.jpg   Sub frames (final design and build)-camaro56-011.jpg
Old May 19, 2009 | 02:50 PM
  #55
BPWilliams's Avatar
Here is how they tie into the cage through the floor....
Attached Thumbnails Sub frames (final design and build)-sm_camaro56-004.jpg   Sub frames (final design and build)-sm_camaro56-050.jpg   Sub frames (final design and build)-sm_dsc01501.jpg
Old May 23, 2009 | 10:17 PM
  #56
FueledSoul's Avatar
Very nice!
Old May 23, 2009 | 10:21 PM
  #57
FueledSoul's Avatar
So i started making new rear brakets. 3rd times the charm i guess. these very close to the previous ones i had made.
Old May 23, 2009 | 10:25 PM
  #58
FueledSoul's Avatar
I started on the rear of the inner tubes frist. the chop saw could only cut 45° but i was still abile to cut what i needed by take some peaces off the saw and by eye balling the cut.
Old May 23, 2009 | 10:29 PM
  #59
FueledSoul's Avatar
I held them in place and used a angle finder to mark where i was going to cut. i had an idea of how close i wanted to run the tubes to the floor boards too.
Old May 23, 2009 | 10:35 PM
  #60
FueledSoul's Avatar
Then i started to mark and cut tubes for the drivers side since it looked easier. i like to knock the easy stuff out first.
Old May 23, 2009 | 10:37 PM
  #61
FueledSoul's Avatar
Old May 23, 2009 | 10:40 PM
  #62
FueledSoul's Avatar
I put the diver side inner subframe up into place to see if i needed to make any other improvements and to see if i was going to have enough room for only a pencil to fit in between the floor boards and sub frames. i made my goal
Old May 23, 2009 | 10:44 PM
  #63
FueledSoul's Avatar
Next i start on the passenger side. i followed the contours the best i could with square tubing and they turned out great.
Old May 23, 2009 | 10:50 PM
  #64
FueledSoul's Avatar
Here they are done. i still have a few things to tweak.
Old May 23, 2009 | 10:52 PM
  #65
FueledSoul's Avatar
i used 16ft of tubing to make both and still had some small scrap left overName:  Picture456.jpg
Old May 23, 2009 | 10:59 PM
  #66
FueledSoul's Avatar
Heres some shots of them under the car but not tacked to the front and rear plates yet.
I used the drain hole pulgs as a gide along with some other things and make sure both were identicaly ran other then the bends up and down bends i had to make.
Old May 23, 2009 | 11:11 PM
  #67
89ROC-Z's Avatar
Car: 89 IROC-Z
Engine: 370 LSX, LS3 Top End
Transmission: Built T-56
Axle/Gears: 9" Aluminum Center 3.89's
Now those are different!! In a good way!!
Old May 24, 2009 | 11:36 AM
  #68
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
they look like alston SFC's, but square! Cool deal, but is all the extra weight worth it?
Old May 24, 2009 | 12:12 PM
  #69
RED_DRAGON_85's Avatar
Car: 85 Camaro IROC
Engine: 5.7 TPI
Transmission: 700-R4
Axle/Gears: open rear, 3.42 gears
he used thinner 14 ga metal vs 11 gauge for that reason.
besides, at most we are talking about 30# over a comparable store bought sfc design that is much less stiff.
besides that... the weight is below the GC of the car, so it helps to bring the CG down, which is good.
all in all, id say that it was worth it
Old May 24, 2009 | 02:12 PM
  #70
customblackbird's Avatar
Car: 87 TA clone
Engine: 70/70 Turbo 5.3 LS
Transmission: bullet proof 2004R
Axle/Gears: ford 8.8, 3.55 gears
looks good. dont the welded points create weak points? i always thought using once peice of tubing is stronger than something of smaller peices welded together. still tho they look good. nice job
can u post pics of that diff cover? lol u look like u did alil reinforcing to that stock steel one. at first i thought it was an aluminum support girdle but its clearly not.
keep up the good work! did u end up boxing the perimeter SFC? or just leaving it hollow?
Old May 24, 2009 | 02:21 PM
  #71
FueledSoul's Avatar
Thanks.
yea i reinforced mine. its definitely not like the ones that incorporate the mains. but if anything it will add some rigidity to the housing .
Old May 24, 2009 | 02:44 PM
  #72
FueledSoul's Avatar
Anyway back to the subframes.
The
14ga 2x1" rectangular tubing is 1.600 Weight per lineal foor
There was 94" of tubing used to make both inner subframes.
= 12.53 lbs total weight
The
14ga 2.25" rectangular tubing is 1.882 Weight per lineal foor
There was 124" of tubing used to make both outter subframes.
= 19.45 total weight
(combined total weight so far 31.98 lbs)
Here is how they look under the car now.
I plan to tie both inner and outer sub frames together like this.
Old May 24, 2009 | 02:51 PM
  #73
Stephen's Avatar
Car: 87 GTA
Did you make a wooden buck after finishing them, before installing them, so that you could duplicate & sell some more?
Old May 24, 2009 | 08:27 PM
  #74
Car: 85 Camaro IROC
Engine: 5.7 TPI
you know, fueled soul, you could go into business with this.
i had (and still have) a friend that makes custom longboard skateboards.
he sold mostly to guys on campus and had a sweet little side job going.
when he graduated last semester, he got a small business license, and is working on a patent for a downhill truck design.
he never thought that his little hobby would blossom into a business, but it has...
the point of all this is...
dont sell yourself short.
you clearly have some fabrication talent and creativity.
there is a definite niche for thirdgen camaro parts that are affordable and well thought out.
if you were to sell your subframe connectors, i'd probably buy a pair, and if they were affordably priced (less than $225) id buy them for sure.
you should think about it.
Old May 25, 2009 | 05:35 AM
  #75
FueledSoul's Avatar
still not done with them yet
Old May 25, 2009 | 05:49 AM
  #76
FueledSoul's Avatar
Thanks!
your compliments are very much appreciated. i have thought about it but id really have to think about it some more. But before i started putting this together and building it i kinda already knew that there was possibility people would be interested in my designed subframes. I could reproduce them, id ovisously make them better and improve upon somethings. . .
Its a real possibility and all think about it more.
Old May 25, 2009 | 08:34 PM
  #77
Car: 85 Camaro IROC
Engine: 5.7 TPI
one thing i would consider is the strength of the "curved" piece you made.
other than that, you have a really good design
Old May 25, 2009 | 08:45 PM
  #78
Mathius's Avatar
Originally Posted by FueledSoul
Thanks man! yea im going to cap the ends i knew someone would ask about that haha, its just not on the top of my list. i want to get everying to where i want it then come back cap the ends and fully weld it off the car. The floor board idea you have is great. but i dont plan to do that.
Make sure you weld all those joints up as well. They might not need it for strength, but it serves the same purpose of keeping moisture out between the tubes. We've all taken a bracket off of a car frame or something and seen the rust that's accumulated behind it.
Looks good. Always happy to see someone just go buy some material and figure it out instead of always posting the same silly questions over and over again. I haven't been posting here much lately again because it's always the same stuff over and over again.
Good job.
Gonna coat'm with bedliner when you're done? I'm not following your design just yet until I see some more of it. From the pictures it kind've looks like you are building them to be bolted in place?
EDIT: After looking at the pics again looks like I'm seeing it wrong. The bolts I saw were for your rear suspension. Is that the stock setup or did you go with something else?
Mathius
Old May 26, 2009 | 09:24 PM
  #79
FueledSoul's Avatar
I re-worked that area tonight for mine own set. like i said if i where to build a set for others id improve upon somethings.
Old May 26, 2009 | 09:32 PM
  #80
Car: 85 Camaro IROC
Engine: 5.7 TPI
the curved piece with the bolts attaches to the rear LCA mounts so that the subframe can be bolted up for easy welding and extra strength at the joint.
unless thats not what you were talking about
Old May 26, 2009 | 09:35 PM
  #81
FueledSoul's Avatar
Deffanatly what i plan on doing
Yea, i agree with you
Good job.
Thanks!
Im probably going to powder coat them.
I built them to swing into place from the rear LCA's. i can take them off and put them back on so everything fits like it was once the inners and outers are tied together with the center tubes. then i can take them off and fully weld each place then bolt them back in and swing them into place so nothing will shift or move im using the rear LCA bolts as a gide for fitment for the intire subframes. just makes it simple, i planned it like that from the beginning
Old May 26, 2009 | 09:39 PM
  #82
FueledSoul's Avatar
Old May 26, 2009 | 09:41 PM
  #83
FueledSoul's Avatar
i was talking about something else
Old May 26, 2009 | 09:47 PM
  #84
Car: 85 Camaro IROC
Engine: 5.7 TPI
sorry, not you, matius
i guess thats what the quote button is for lol
Old May 26, 2009 | 09:52 PM
  #85
FueledSoul's Avatar
Old May 26, 2009 | 10:58 PM
  #86
87CIZ's Avatar
Car: 88' Iroc-Z
Engine: LQ9
awesome job. Someone gave me a set of alston sfc's but i still havent decided what kind i want for the perimeter sfc's. I can't wait to see how they tie in. Great job. I envy your skills.
Old May 27, 2009 | 10:36 PM
  #87
FueledSoul's Avatar
Old May 27, 2009 | 10:39 PM
  #88
FueledSoul's Avatar
So i re-worked the passenger inner sub frame a bit. I wanted to tuck it up tighter and have it match the drivers side floor board to sub frame gap.
Old May 31, 2009 | 08:41 PM
  #89
FueledSoul's Avatar
So i finally got around to the the outer sub frames again, i had to notch and modifie them so they would touch the front sub frames 360°. Why? . . . well because now these sit 100% flush and can be welded 360° I have built ever peace this way. I believe 360° of weld around the factory sub frames are better then wimpy lines of welds.
I have to prep a few areas, but I'm almost ready to tack down the inner and outer sub frames and start on the center tubes!!!
Passenger side
Old May 31, 2009 | 08:43 PM
  #90
FueledSoul's Avatar
Old May 31, 2009 | 08:44 PM
  #91
FueledSoul's Avatar
Drivers side. i need to clean both the left and right sides up but i will do that after the center tubes are done and the sub frames are off the car
Old May 31, 2009 | 09:00 PM
  #92
Stephen's Avatar
Car: 87 GTA
Cutting across them was no doubt the easy part...But how did you make the lengthwise cuts? Bandsaw?
You gonna make notches at each point along them, as the floor drops to keep them touching 110%?
Old May 31, 2009 | 09:54 PM
  #93
FueledSoul's Avatar
I wish i had a band saw! i wish i had a lot of other tools too!
You mean the notches i made? I used a cut off wheel. oh, no not the floor boards just the ends of the sub frame connectors to the factory frame rails them self. sorry if that was confusing
Old Jun 9, 2009 | 10:55 PM
  #94
FueledSoul's Avatar
I got started on the center tubes last week. i pretty much wrap them up tonight.
Cardboard worked great for mocking up the angles.
  #95
FueledSoul's Avatar
last set of tubes to be tacked on!
Old Jun 9, 2009 | 10:58 PM
  #96
FueledSoul's Avatar
Here they are! i will double check my work tomorrow before i cut the tacks off the factory frame rails and i will take some better pics of them off the car.
Old Jun 9, 2009 | 11:10 PM
  #97
FueledSoul's Avatar
Old Jun 10, 2009 | 08:47 PM
  #98
FueledSoul's Avatar
Here they are off the car.
Looking at them from the top.
Old Jun 10, 2009 | 08:49 PM
  #99
FueledSoul's Avatar
Looking at the from the bottem.
Old Jun 10, 2009 | 09:02 PM
  #100
FueledSoul's Avatar
Both sides weigh the same and are built close to identical as possible.
