Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Sub frames (final design and build)
Old Jun 10, 2009 | 09:17 PM
  #101
FueledSoul's Avatar
Car: 84 camaro, 88 trans am, 98 camaro
Engine: Modded , stock, LSX modded
Transmission: 700r4, 700r4, t-56
Axle/Gears: 327, 308, 373
Re: Sub frames (final design and build)
Just for fun i pulled out my 8 point.
  #102
FueledSoul's Avatar
Old Jun 10, 2009 | 11:01 PM
  #103
Scamo-2.8's Avatar
Car: 1989 Camaro RS
Engine: 1990 - 5.7
Transmission: Tremec 3550
Axle/Gears: 9 Bolt - 3:45
My goodness, I'm speechless, those are beautiful. I too, envy your talent.
Old Jun 11, 2009 | 12:05 AM
  #104
89ROC-Z's Avatar
Car: 89 IROC-Z
Engine: 370 LSX, LS3 Top End
Transmission: Built T-56
Axle/Gears: 9" Aluminum Center 3.89's
Very nice!!!!!
Old Jun 11, 2009 | 08:23 AM
  #105
3rdgenmaro's Avatar
Car: 88 IROC
Engine: 97 5.7 Vortec LT4 hotcam
Transmission: 700 r4
They look great! Good job.
I am going to build a set sometime in the near future, whenever time allows. Probably this winter. You have given me some great ideas. Im not going quite as strong as yours, but this thread will be a huge help. Great build pics along the way. Thanks
Old Jun 11, 2009 | 07:17 PM
  #106
iroc a 86 berli's Avatar
Car: 86 berlinetta 92rs gfx
Engine: 4 bolt 384 stroker
Transmission: th350 4000 stall manual/T brake
Axle/Gears: 87 iroc 9 bolt
those last pics just made me wanna start my own ground up car again! nice work, now lets see em in the car!
Old Jun 13, 2009 | 02:02 PM
  #107
BPWilliams's Avatar
WOW those do look nice! Great Job!
I was having problems trying to figure out how to tie the SFC's to the roll cage so I made post off the SFC and tied the roll bar hoops into the post. It ended up sandwhiching the floor pan between the SCF's and the main cage. Worked out pretty good..
Attached Thumbnails Sub frames (final design and build)-dsc00041.jpg   Sub frames (final design and build)-dsc00042.jpg   Sub frames (final design and build)-camaro56-026.jpg
Old Jun 18, 2009 | 03:20 AM
  #108
FueledSoul's Avatar
Thank you! im a firm believer that you can do anything you put your mind too
Old Jun 18, 2009 | 03:21 AM
  #109
FueledSoul's Avatar
Originally Posted by 89ROC-Z
Very nice!!!!!
Old Jun 18, 2009 | 03:22 AM
  #110
FueledSoul's Avatar
thanks! and your welcome!
Old Jun 18, 2009 | 03:24 AM
  #111
FueledSoul's Avatar
soon they will be im kind of jumping around all over the car latey.
Old Jun 18, 2009 | 03:25 AM
  #112
FueledSoul's Avatar
thanks!
Old Jun 18, 2009 | 03:30 AM
  #113
FueledSoul's Avatar
I should have these fully done with in the next week or two. im still planing on having these poweder coated but i havent really looked into it that much latey.theres some places around me that do it i might make some calls this week. anyway once i get them all capped up and welded i will post some pics.
Old Jun 23, 2009 | 05:46 PM
  #114
357transam's Avatar
Car: 1986 T/A
Engine: 350 bored .040, s/r torquer heads
Transmission: 700r4, tci shift kit
Axle/Gears: stock borg warner
I think those things would probably be the only thing left if your house was ground zero for a nuclear bomb.... I think they might make the car a wee bit stiffer. Great job!
Old Jun 23, 2009 | 08:59 PM
  #115
RED_DRAGON_85's Avatar
Car: 85 Camaro IROC
Engine: 5.7 TPI
Transmission: 700-R4
Axle/Gears: open rear, 3.42 gears
thats amazing that they weigh the exact same despite taking different paths on the contour of the car...
then again, i guess you planned it that way...
great job.
you might consider welding a plate to the part that hugs the floor and has so many bends.
if you welded a plate to the outer surfaces it would strengthen it a lot.
im not sure how strong it would need to be or how much stress that area would have, but its something to think about.
if you can give me some semi accurate plans and where you made cuts ect, i can try and model them in solid works... this would let me find any weak spots or stress concentration spots and you could add extra metal where its needed.
might be more work than you want to do but just one more thing to think about i guess.
what i would need is essentially a piece by piece drawing or list with angles lengths and stuff like that...
Old Jun 29, 2009 | 03:43 PM
  #116
omnipotentgoku's Avatar
Car: 1987 IROC Z
Engine: 350 TPI L98 block
Nice!!
Old Jun 30, 2009 | 02:21 AM
  #117
FueledSoul's Avatar
. thanks man!
Old Jun 30, 2009 | 02:26 AM
  #118
FueledSoul's Avatar
great job.
yea i was thinking that they would be a few lbs diffrent but came out identicle. and agin thanks man
i plan to go back and add some peaces all show what im doing once i get to that
i might once im done and have some spare time
Old Jun 30, 2009 | 02:27 AM
  #119
FueledSoul's Avatar
Originally Posted by omnipotentgoku
Nice!!
thanks
Old Jun 30, 2009 | 05:55 AM
  #120
jg04222's Avatar
Car: '82 Z-28
Engine: 355
Transmission: TH-400, 8" ATI MRT
Axle/Gears: Moser 9", 4.56's
nice job man. looks like you incorporated some aspects of the UMI subframe connectors. I had every intention of making my own, until i got the UMI's as a present when i graduated from college.
Old Aug 12, 2009 | 11:38 AM
  #121
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
Axle/Gears: 10-Bolt/2.73
I'd pay $300 for your set. It is definitely worth the $200 every other company lists theirs' at and that's just for the outside set SFC's. This includes the inner workings as well and tie's them all together. This set is kind of like buying UMI and Alston's, then tying both of them together in the middle. GREAT GREAT GREAT WORK, Tony the Tiger would be proud. I plan to get an 8pt cage as well when I do my SFC's and floor pans.
-Take care, hope to see more from you.
Old Sep 4, 2009 | 05:32 AM
  #122
godjackass's Avatar
Car: 1987 iroc
Engine: blown up for now
Axle/Gears: 10 bolt/stock
itd be nice if you duplicated a set. i would definitely buy some.
Old Sep 4, 2009 | 05:47 AM
  #123
Twin_Turbo's Avatar
I'm going to copy these, or most of these. By far the best set I have seen. the rest doesn't even come close. I'll probably have the bowed section rolled so it's easier to fab up without having to do all the angle cuts.
Old Sep 4, 2009 | 09:34 PM
  #124
FueledSoul's Avatar
i dont see anything that looks like UMI, i guess the only thing that resembles them is the overlap on the steel tubes on the passnerside outter subframe. nice lucky you, UMI makes good stuff
Old Sep 4, 2009 | 09:36 PM
  #125
FueledSoul's Avatar
Thanks man
Old Sep 4, 2009 | 09:39 PM
  #126
FueledSoul's Avatar
Im not to that point yet, but. Consider these to be more like a trail and error set.
Old Sep 4, 2009 | 09:41 PM
  #127
FueledSoul's Avatar
Old Sep 20, 2009 | 06:43 PM
  #128
my89's Avatar
Car: '89 Formula
Engine: 305 TBI
Any pics of how they looks welded in place under the car?
Old Sep 20, 2009 | 07:50 PM
  #129
FueledSoul's Avatar
i'v been fairy busy so, The only thing left is to weld the tacked caped ends then decide if i want to powder coat them or cheap out and just primmer/paint then install them . im hoping this will be done with in a few weeks or less and i will post some pics of them painted and on the car
Old Sep 26, 2009 | 06:38 PM
  #130
radical82's Avatar
Car: '82 Camaro
Engine: 383
Transmission: TKO 5 speed
Axle/Gears: 31 spline 9" with 4.56:1
That's some really great looking work!!!!! Should tie the car up quite nicely, I would think! Doing a similar thing on mine, but I won't clutter up your thread with my stuff. Just new on here, sure don't want to step on anyone's toes..... Anyway, great work!!!
Old Oct 6, 2009 | 01:51 AM
  #131
DBLTKE's Avatar
Car: '91 Camaro Z28, '85 Camaro Z28
Engine: LB9, LB9
Transmission: T5, 700r4
Axle/Gears: Eaton 3.73 Posi, 3.23 Posi
Those look amazing. Nice work.
Old Oct 6, 2009 | 02:25 AM
  #132
ericjon262's Avatar
Car: 85 2M6, 87 'Bird 88 'burb
Engine: LX9, LG4, L05
Transmission: F23, 700r4, 700R4
Axle/Gears: 3.63, 2.73, 4.10
Very nice!!!!!
Nice!!
If I had $300 I would definately be willing also!
I'd be willing to let you install them on my "test car"
Old Oct 25, 2009 | 07:20 PM
  #133
Dr. Z's Avatar
Car: 91' Camro Z28
Engine: 5.0 TPI
I have been searching the net for my own project and this is the best I've seen yet! Love your work so far.
Old Oct 25, 2009 | 08:56 PM
  #134
radical82's Avatar
Car: '82 Camaro
Engine: 383
Another thing to add.....
It sure is good to see someone out there designing, thinking, and fabricating their own parts!!!!! Bolt ons are ok...to a point.. Most are designed with a "one size fits all" mindset.... when building your own components and pieces you're able to customize and tweak things around, maybe change an angle here or add a gusset there to make the mod work better for you and your specific application!!!!
Good job so far Fueled---now keep it going and get that old Gen III to be EXACTLY what you want it to be and not a carbon copy of everyone else's!!!!!!!
Go for it, dude!!!!!!!
Old Oct 28, 2009 | 03:39 PM
  #135
adore's Avatar
Give them to me now!!..with the roll bar. Thanks
Old Nov 6, 2009 | 03:42 PM
  #136
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
Installed them yet?
Old Nov 6, 2009 | 04:08 PM
  #137
yea, lets see em installed already!!
Old Dec 14, 2009 | 08:10 PM
  #138
Josh R's Avatar
Car: Iroc
Engine: 350 4-bolt
Transmission: T5 non-W/C
Axle/Gears: 3.27 Open
Dont rush him haha. Great job. I have alston inner style and now i plan on getting UMI outer styles and triangulating them. Yours look amazing tho. I can't wait to see them finished and powdercoated up. A++++++++++++.
Old Dec 15, 2009 | 12:46 PM
  #139
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
this car is turning out amazing. i just hope you actually beat on it when you get it going down the road.
Old Dec 26, 2009 | 03:20 PM
  #140
metalhead212121's Avatar
Car: 91 Firebird Formula
Engine: For me to know.....
Transmission: and you to find out....
updates??
Old Jan 17, 2010 | 12:57 AM
  #141
lowflyr's Avatar
Car: 87IROC/88GTA/02Sierra/04GrandPrix
Engine: 406 / 305 / 4.8 / 3.8
Transmission: T56 / T5 / 4L60e / ??
Axle/Gears: 3.70 / 3.45 / 3.42 / ??
Anyway back to the subframes.
The
14ga 2x1" rectangular tubing is 1.600 Weight per lineal foor
There was 94" of tubing used to make both inner subframes.
= 12.53 lbs total weight
The
14ga 2.25" rectangular tubing is 1.882 Weight per lineal foor
There was 124" of tubing used to make both outter subframes.
= 19.45 total weight
(combined total weight so far 31.98 lbs)
Here is how they look under the car now.
I plan to tie both inner and outer sub frames together like this.
LMFAO, here I am playing along reading the posts, and I see this!! That's MY GTA you're drawing on, lol. That was a while ago. I want royalties for using my images. I'll accept payment with a set of those schnazzy subframe connectors you're building there, lol.
Great job, can't wait til you post pics of them installed. I can supply alot of great pictures of these cars stripped if you have any other ideas you'd like to work on. Youre giving me ideas!
Cheers,
-Brad.
Old Jan 17, 2010 | 01:04 AM
  #142
Stephen's Avatar
Car: 87 GTA
Remind me of my Kenny Brown Double Diamond SFCs.....
Old Jan 18, 2010 | 06:45 AM
  #143
3rdgenmaro's Avatar
Car: 88 IROC
Nevermind. Found it. 65"
Old Jan 18, 2010 | 08:01 AM
  #144
Twin_Turbo's Avatar
sizes are metric (mm):
Old Mar 2, 2010 | 08:22 PM
  #145
simzjr1's Avatar
Car: 1986 Iroc
Engine: 355ci
Axle/Gears: 2.73:1
First off, allow me to commend you on such an amazing fabrication. You have skill, determination and knowledge that many of us desire.
My question is why so many of the SFC have a bolt on aspect at the LTA.
I want to put SFC on my mild engined 86 IROC but I think it would be simpler just to make SFC's identical to the ones above this post and not bolt onto the LTA but rather just weld it alongside the mounting box.
So my question is, would not making to box that bolts to the LTA remove alot of the structural integrity of the design?
Thanks for all your input!
Old Mar 2, 2010 | 08:24 PM
  #146
Stephen's Avatar
Car: 87 GTA
LTA? That's a term I've never seen used before...
Old Mar 2, 2010 | 08:26 PM
  #147
simzjr1's Avatar
Car: 1986 Iroc
Engine: 355ci
Axle/Gears: 2.73:1
Sorry, maybe I misuse it, I just call it a lower trailing arm...you know the trailing arms that connect the sub frame to the diff...
Old Mar 2, 2010 | 08:59 PM
  #148
gregsz-28's Avatar
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
LCA... lower control arm is what they are most commonly called
Old Mar 2, 2010 | 09:07 PM
  #149
89ROC-Z's Avatar
Car: 89 IROC-Z
potatoe potahtoe
Old Mar 3, 2010 | 12:43 PM
  #150
simzjr1's Avatar
Car: 1986 Iroc
Engine: 355ci
Axle/Gears: 2.73:1
nobody knows?
