Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Braided stainless steel fuel lines
Old Sep 15, 2009 | 01:34 PM
wildjyoung's Avatar
Car: 1991 Trans Am GTA, 2003 Grand Am GT
Engine: 350 Tune Port
Hello Everyone,
Due to rust on my fuel lines I have decided to convert over to braided stainless steel lines with AN fittings. I made a diagram on how to connect via the existing TPI fuel line and gas tank. If you do not mind, review the attached diagram and let me know if I have missed anything or if there is any reason the braided stainless line is a bad idea.
Thanks!
Josh
File Type: pdf
Old Sep 15, 2009 | 06:18 PM
86irocu's Avatar
Car: 1986 Iroc-Z
Axle/Gears: 3.73 posi
Re: Braided stainless steel fuel lines
I have replaced all my lines with stainless braided as well. here is a pic of how I did my fuel rail, pressure and return line.
As for the tank, I used a hard line fitting that allows me to use -8an fittings for both the pressured and return line.All the fittings and filter are Earl's. I havent had a problem with the braided stainless steel lines. You might want to get some thick gloves when your putting those lines in the fittings, they will tear you up pretty good.
Old Sep 15, 2009 | 09:30 PM
wildjyoung's Avatar
Wow, looks great! I purchased -6 AN lines and fitting. Should I have gone with -8 AN?
I may go with hard lines to the tank as that would look better. Although, no one would see them.
Also, what fuel filter did you use? I could not find many that would hold up to fuel injection.
Old Sep 16, 2009 | 08:53 AM
Pocket's Avatar
Car: 91 Trans Am
AN-8 is total overkill
You can see by the diameter he is running dual AN-6 which is the most common and still plenty enough for anything on the street. AN sizes are based on diameter. AN-6 = 6/16" = 3/8" which is stock fuel feed. AN-8 = 8/16"=1/2" which your stock pump will not be able to keep adequate pressure on the entire length of the lines
How far have you looked for a filter? There are quite a few available and if you dont like them you can buy adapter fittings to reuse the stock style
Old Sep 16, 2009 | 09:06 AM
wildjyoung's Avatar
That's what I thought but figured maybe I had something wrong.
I found a filter (Russel Performance) but liked the Earl's a littl better because it had a replacable element. However, I could not find a pressure rating. I went with the Russel because it had a stainless steel filter disk that filters out anything greater than 40 microns, which should be way more than I need.
Old Sep 16, 2009 | 09:26 AM
Pocket's Avatar
Car: 91 Trans Am
Filters usually arent pressure sensitive like regulators
Old Sep 20, 2009 | 01:54 PM
HCR13's Avatar
Car: 1987 Trans Am
Engine: 355ci L98 soon to be turbo'd
Axle/Gears: 2.73 posi
I have -6AN braided hoses in the engine bay. Looks and works fine.
Old Sep 21, 2009 | 01:31 PM
86irocu's Avatar
Car: 1986 Iroc-Z
Its been a while since i put my lines in, they may be AN-6. for some reason I thought I had AN-8. As for the filter, i used an earls filter that was rated for fuel injection. I cant recall the model number but I can take a look for you if you would like.
Old Sep 21, 2009 | 03:20 PM
Shagwell's Avatar
Car: projects.......
Unlike the metal lines and/or the teflon lined/crimped end SS braid, the typical rubber lined SS braid hose(with the "pretty" anodized aluminum fittings) has a lot shorter life span.
There is no form of rubber hose that is fuel "proof". They are all fuel(and/or oil) "resistant".
Old Sep 21, 2009 | 04:44 PM
tom86iroc's Avatar
Car: 1986 iroc
Engine: alum. head 350 supercharged
Transmission: 6speed
Axle/Gears: ford 9in 3.90 35 spline moser axles
i run #8 from my tank to a russell 40 micron filter to my 110fi fp #8 all the way to the front to a mallory 3160 filter which is 10 micron for FI then i run 6 outta that to my rails and #8 back to the tank
Old Oct 13, 2020 | 04:32 PM
3rd gens rule!'s Avatar
Car: 87 trans am
Engine: 5.0 TPI
Axle/Gears: Stock axles 2.73
Attachment 426255
Attachment 426256
I was wondering were you got your AC delete pulley in the pics?? I cant seem to find one.
Frozer!!!
Jan 19, 2024 04:55 PM
theshackle
Mar 5, 2017 06:37 PM
Andrew6.688
Dec 13, 2015 10:59 AM
AkDrifted
Aug 17, 2015 07:45 PM
