Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
lets see some pics of your custom mods and/or fabrication
Old Oct 5, 2009 | 06:21 PM
mikehaase1norse's Avatar
Car: 1991 Trans Am vert
Engine: tpi
if its custom or home made i wanna see it! lets see what you've built or your favorite mod!
Old Oct 5, 2009 | 06:29 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: lets see some pics of your custom mods and/or fabrication
haha i like this.... heres my homebuilt turbo system. Quite proud of it for my first attempt. All made with cutoff wheel, sawzall, chop saw, and my own creative ability.
To this
Old Oct 5, 2009 | 06:34 PM
Engine: tpi
just plain sick, im mad jealous, wanna come do that to mine? ill even buy ya a plane ticket lol
Old Oct 5, 2009 | 06:36 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
almost plug-and-play autometer gauge setup for my TA, all fits in the stock gauge pod and plugs into the factory connectors/harness. Just 3 extra wires for the water and oil temp gauges
widened interior panels, just one pic, its all pretty much done took a looong time.
offset control arms by Spohn, still holding strong, they didnt break!
a little bit of a mini-tub
theres more, but i dont have pics.
-Phil
Old Oct 5, 2009 | 06:38 PM
Engine: tpi
i dig the gauge setup, how much dough it set ya back?
//<86TA>\\'s Avatar
Car: 86 Trans Am
those turbo headers really did come out well Orr89RocZ, quite impressed with what you were able to accomplish.
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Love that mini tub and offset arms. I wanted to do something like that to mine as I love fat tires out back
I know i could do another build better now that i've done this one, but it took 9months to get it running and its been about a month and a half of trying to tune it. Not sure i want to do another build again haha. Expensive too
Old Oct 5, 2009 | 06:40 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
about a grand in gauges, everything else was peanuts.
Engine: tpi
I know i could do another build better now that i've done this one, but it took 9months to get it running and its been about a month and a half of trying to tune it. Not sure i want to do another build again haha. Expensive too[/quote]
oh i bet
Old Oct 5, 2009 | 06:41 PM
Engine: tpi
damnnnn worth it tho?
Old Oct 5, 2009 | 06:42 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Also made a 3.5" MAF sensor based onwork done by DOC here on these forums. Worked good but I didnt pick up anything from it, but i also never retuned it 100%
looked better than stock TPI box i think
Old Oct 5, 2009 | 06:43 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
electric full sweep guages are not cheap, speedo and tach were like 250 each, and the little ones were almost 200 each.
They are more accurate, look neat and the project was fun, so it was worth it. Not sure if i would do it again though, unless sombody was buying it.
Mechanical guages would be a lot cheaper, but would not suit what i was looking for.
Old Oct 5, 2009 | 06:45 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Was it hard to install everything in the dash? Did factory wiring kinda plug and play nice? I wanted a new tach/speedo to go with the new turbo setup as i think it will do more than 145mph
Old Oct 5, 2009 | 06:48 PM
Engine: tpi
well your happy with the turnout thats all that matters, i like your ideas but that would never fit my budget
Old Oct 5, 2009 | 07:04 PM
fast82z's Avatar
Car: 82 Z28
Engine: TT LS
Transmission: 4L80E
Axle/Gears: S60 3.54's
I'm going to say how I kept all my turbo stuff under the stock hood and maintained a street exhaust:
Old Oct 5, 2009 | 07:12 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
mine doesnt fit the stock hood or aftermarket haha. Very nice setup there
Heres my 2 ypipes i've made for my car
Old Oct 5, 2009 | 07:26 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Camaro's guage pods are different shape, without having one i could say.
As for the birds, all the wiring was there, just had to use little machine screws and nuts to bolt the wires to the back of the pod, sandwiching the printed wiring on the back like the factory did with the screws into the guages. The only wires that were not there were for the water temp and oil pressure. Factory is a 1 wire sender, the autometer ones were 2 and 3 wire, so i couldn't use the factory signal wires for those two guages. everything wlse, volts, fuel level, speedo, tach and backlighting were usable. It is however a very tight fit, the center of the bird pod is deeper than the 2 ends, not a big deal for the 2 1/16 guages, but the speedo and tach dont fit. They sit about 3/8" up from the face of the aluminum mount for the gauges that i made on little spacers i made from black ABS pipe. I had to cut the clear plastic lense form the stock pod in half because the speedo and tack stick through it a bit.
Old Oct 5, 2009 | 08:38 PM
85_ZED28's Avatar
Car: '85 Z28
My favourite is the shift light I made last year, it was a fun project! Here's a video set at 4500rpm.
Old Oct 5, 2009 | 08:51 PM
Iroc-Z28Man's Avatar
Car: 86 Iroc-Z28 Camaro/84 BMW M Power
Engine: 350TPI/ S50
Transmission: t-5 five speed/ 5 speed
Axle/Gears: 3.42 posi/ 3.73LSD
That shift light is sick as ****! Thats soooo cool.
Old Oct 5, 2009 | 08:59 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
i remember that, its pretty neat!
Old Oct 5, 2009 | 09:06 PM
Engine: tpi
shift light makes me wish i had a 5 speed even more :/
Old Oct 5, 2009 | 10:34 PM
Primetime91's Avatar
Car: '88 Camaro (Gone...)
Hey, I remember that light One of the coolest things I've seen on here.
Just curious, what's it show for reverse?
Old Oct 6, 2009 | 04:27 PM
85_ZED28's Avatar
Car: '85 Z28
Thanks guys. Reverse looks like a lower case ' r '
Old Oct 6, 2009 | 04:41 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
I got a full manual TH400 trans, i could use a light And my cig lighter is broke so i can use that hole for something... probly gonna try to put the boost controller in there tho
Old Oct 6, 2009 | 04:45 PM
3rd gen Will's Avatar
Car: 91 Z28, 2000 T/A
Engine: SBC 355, LS1
Transmission: T56, T56
Axle/Gears: 10bolt 3.73, 3.42
Dude, That shift light is BAD ***!!!!
Old Oct 6, 2009 | 04:59 PM
FYRCHKN's Avatar
Car: 1988 SC Convertible
Engine: LT-1
Axle/Gears: 3.23 posi w/PBR's
This is my kind of thread. I have WAY more custom fabbed mods than these, but here's a few just for starters:
My hood:
https://www.thirdgen.org/forums/fabr...tor-build.html
My tail lights:
https://www.thirdgen.org/forums/body...il-lights.html
91-92 T/A GFX:
https://www.thirdgen.org/forums/body...-t-fender.html
Rear Wing:
https://www.thirdgen.org/forums/body...-gen-wing.html
....I can't give away all my secrets.
Old Oct 6, 2009 | 06:57 PM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
GIFTED!!
Old Oct 6, 2009 | 07:00 PM
Engine: tpi
Originally Posted by t-top havoc
GIFTED!!
Old Oct 6, 2009 | 08:57 PM
85_ZED28's Avatar
Car: '85 Z28
It's a good spot for a light. I plan to move the cigarette lighter to the center console.
Old Oct 6, 2009 | 09:42 PM
Firebat's Avatar
82-90 Clear and reflective(horizontal lines like stock) front turn lamps:
Those are kind of old news though. I went with 91-92 firebird turn signals for the new nose. I'm going to like these modified 91-92's because once I cut off the lense, the new front lense can just be bolted down and easily replaced, not glued on. Lot easier to make. Going to clear and not clear reflective because will modify the bulbs to have both filaments on making them brighter, also will be behind a grille. Got to do a little painting yet on the 91-92 turn signals but here is a progress pic:
Old Oct 6, 2009 | 10:00 PM
Pocket's Avatar
Car: 91 Trans Am
I put two blowers under a stock hood and it actually works
Old Oct 6, 2009 | 10:09 PM
FYRCHKN's Avatar
Engine: LT-1
Do you have a thread on these? I really, really want more info on this. I have a cracked passenger lens and I don't want to give my arm for a pair of new ones.
Old Oct 6, 2009 | 10:25 PM
Stephen's Avatar
Car: 87 GTA
How is that ducted from the air filters all the way through the open (in the pic) throttle body?
Old Oct 6, 2009 | 10:39 PM
Pocket's Avatar
Car: 91 Trans Am
Inlet is in the rear of the blowers and pressurized outlet is on the bottom facing towards the headers
Not shown are the 'hats' that connect the outlet to 2.5" pipe that is ducted through the front plates up to the 2 into 1 intercooler which goes directly to the TB much like Orr's setup
There is a thread about it in this forum. I havent had much time to finish up the little details of the build
Old Oct 6, 2009 | 11:09 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Just about every picture I take of my car is a custom mod. I wouldn't know where to start to post a single picture.
You might want to be more specific in your request.
Old Oct 6, 2009 | 11:22 PM
Engine: tpi
idk whats your favorite mod, or most recommended, or easiest or hardest its up too you!
Old Oct 6, 2009 | 11:35 PM
punkdude908's Avatar
Car: 1983 Pontiac Firebird
Engine: LG4 305ci 4bbl
Axle/Gears: 10-bolt open diff.
//<86TA>\\- i like that cluster you made! what are the specs for those gauges? how'd you go about fitting them into the bezel like that? i was thinking of doing something similar.
Old Oct 7, 2009 | 07:16 PM
Firebat's Avatar
https://www.thirdgen.org/forums/auto...-firebird.html
Old Oct 7, 2009 | 10:00 PM
Car: '87 Camaro
Insanity I say..INSANITY!!
Twin turbos,twin blowers,fab skills,electric//wiring skills...I've gone over the deep end...wheel stands,alchy....s**t
I can't even fab a good lie!!!
I..N..S..A..N..I..T..Yyy
Love it tho- you guys//gals are inspiratioal -keep up the uniqueness!
Old Oct 8, 2009 | 06:23 AM
Orinackra's Avatar
Car: 06 SRM M6 GTO, 98 Grand Prix GTP
I'm working on something similar, although I am using a type of adhesive on mine. I'll post pics later on today. Along with some of my other mods.
Old Oct 8, 2009 | 04:43 PM
Orinackra's Avatar
Alright, heres my corner light. I only have one done. (passenger obv) Its quarter inch thick lexan painted black and secured with black rtv silicone. Sorry for the crappy pics, but you get the idea. I need another housing to do the other side, cause I dont want to waste the one I have.
Old Oct 20, 2009 | 01:34 AM
  #42
cprepared125's Avatar
Car: 85 Z28 scca C Prepared
Engine: 5.7 348 RWHP
Transmission: t5
Axle/Gears: dana 44 3.41
here's a pic of the rear bulkhead I made to seperate the fuel cell from the drivers compartment and the hinges I made to hinge the trunk lid for re fueling. And my hand cut lexan rear window
Attached Thumbnails lets see some pics of your custom mods and/or fabrication-bulkhead2.jpg   lets see some pics of your custom mods and/or fabrication-rear-hatch.jpg
Old Oct 20, 2009 | 01:56 AM
  #43
ericjon262's Avatar
Car: 85 2M6, 87 'Bird 88 'burb
Engine: LX9, LG4, L05
Transmission: F23, 700r4, 700R4
Axle/Gears: 3.63, 2.73, 4.10
Thats pretty trick, I like it.
Old Oct 20, 2009 | 02:10 AM
  #44
ellocojorge's Avatar
Car: 1991 camaro rs
Engine: 305 tbi
Transmission: t5
Axle/Gears: stock
that one is awesome!!! any links to how it was done?
Old Oct 20, 2009 | 07:20 AM
  #45
camarozz383's Avatar
Car: 1989 camaro rs
Engine: ls 5.3 carb
Transmission: t56 six speed
Axle/Gears: 3:73
you got to be shiten me!!
Old Oct 20, 2009 | 10:45 AM
  #46
ghettocruiser's Avatar
Car: 86 Trans AM
Engine: LS1 (not stock...)
Transmission: Built T56
Axle/Gears: Strange 12-bolt w/ 3.73
My custom double hump T56 crossmember, retaining the Spohn tq arm mount.
My y-pipe. All stainless except for the merge, 3" e-cut out with turn down, and stainless v-bands at each joint.
Guage setup. The wideband is missing in this shot.
Full 4th gen A/C system. Im particularily proud of that one haha.
Man...there is so much stuff. Havent even cracked the surface now that I try to write it all out.
J.
Old Oct 20, 2009 | 12:37 PM
  #47
85_ZED28's Avatar
Car: '85 Z28
J.
wow
Old Oct 20, 2009 | 02:31 PM
  #48
BPWilliams's Avatar
Just a couple... the thrid link is probably the best though...
Goin Racing!
The third link is connected to the rear-end Link.....
Old Oct 20, 2009 | 02:37 PM
  #49
BPWilliams's Avatar
AND, can you say Z06.....
with tire.....
Old Oct 20, 2009 | 03:09 PM
  #50
^^^That's pretty hardcore right there
No side mirrors, headlights, no dash even. How much does your car weigh now?
