Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Fabing floor pan
Old Oct 27, 2009 | 10:08 AM
marekdennhardt's Avatar
Car: 1985 Camaro
Engine: 2.8l
Axle/Gears: Stock
Fabing floor pan
Hey im in the process of making a custom floor pan. I'm wondering if its 100% necessary to bead roll it.
Here is a picture of what im taking about
or check out way more pics of the floor at my car restoration journal
http://www.cardomain.com/ride/3382110
Attached Thumbnails Fabing floor pan-img00186.jpg   Fabing floor pan-img00185.jpg
Old Oct 27, 2009 | 10:11 AM
radical82's Avatar
Car: '82 Camaro
Engine: 383
Transmission: TKO 5 speed
Axle/Gears: 31 spline 9" with 4.56:1
Re: Fabing floor pan
It's going to rattle and "oil can" like crazy if you don't... alternative could be some extra bracing on the bottom, but they add a lot of weight and usually just end up being fugly......
Old Oct 27, 2009 | 10:19 AM
Car: 1985 Camaro
Engine: 2.8l
Axle/Gears: Stock
hmm.. ill call around right now and see how much it will be to get it bead rolled.. I already shaped the metal though to fit. (mostly) will getting it bead rolled dramatically change the size of the peice of metal i have cut?
Old Oct 27, 2009 | 11:29 AM
radical82's Avatar
Car: '82 Camaro
Engine: 383
No, the bead roll actually stretches the metal at the bead more then it shrinks the overall dimension of the piece.... shouldn't be a problem at all. I've done similar patches on numerous cars, about 3 shallow beads running the length of the piece will do fine....sometimes too many beads cause more problems then they cure....
Old Oct 27, 2009 | 02:18 PM
Car: 1985 Camaro
Engine: 2.8l
Axle/Gears: Stock
Alright. I called a hot rod builder and he said that with 19 gauge steel it would be good enough to be left flat. But, he said if i bend a shallow x from corner to corner, like duct work panels, into it, that it will be more rigid and should be plenty good for this floor pan.
I'm going to try this next weekend, unless anyone else has a better idea
Old Oct 27, 2009 | 02:26 PM
Stephen's Avatar
Car: 87 GTA
I'm not sure I'd want my 200lb butt sitting of a flat, un-reinforced plate, of 19-gauge steel.
Old Oct 27, 2009 | 03:25 PM
Car: 1985 Camaro
Engine: 2.8l
Axle/Gears: Stock
Yea you make a good point. I'll call around and check prices to get it beaded. It cant be too much
Old Oct 27, 2009 | 03:27 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
definitely bead roll it, even just rolling an "x" in the pan would work. It will look more professional as well.
Old Oct 28, 2009 | 09:39 AM
Car: 1985 Camaro
Engine: 2.8l
Axle/Gears: Stock
I can't find any company that does bead rolling.
What kind of place will have that?
Old Oct 28, 2009 | 10:02 AM
Car: 1985 Camaro
Engine: 2.8l
Axle/Gears: Stock
Found a place.. Took about 15 calls
Old Oct 28, 2009 | 12:54 PM
jg04222's Avatar
Car: '82 Z-28
Engine: 355
Transmission: TH-400, 8" ATI MRT
Axle/Gears: Moser 9", 4.56's
props to you on the floor/subframe repair; most people would have canned the project at the sight of that. what gauge sheet did you make the floorpan out of? i did mine in 16 ga, but i didn't have to do nearly as much as you.
good luck with the bead rolling; that, along with the seat mounts (if you're going to reuse the factory seat mounts) should add a considerable amount of strength to it.
Good luck man.
Old Oct 28, 2009 | 02:11 PM
Car: 1985 Camaro
Engine: 2.8l
Axle/Gears: Stock
Thanks for the compliment.
Im using 19 gauge steel and I will replace the factory seat mount.
Also I found out that my school has a bead roller that I can use for FREEE so thats a good thing.
Old Oct 28, 2009 | 03:34 PM
adore's Avatar
Your floor looks just like mine, I've gotten the complete left floor pan from carquest (here in Canada) for about 300$, just need to weld it to place.
Old Oct 28, 2009 | 09:03 PM
Car: 1985 Camaro
Engine: 2.8l
Axle/Gears: Stock
sweet deal man.
I wont be welding mine till next weekend
Old Oct 31, 2009 | 11:04 AM
Rich2279's Avatar
Car: '98 Mustang GT
Engine: '03 4.6L
Transmission: T45
Axle/Gears: DK
Summit has this bead rolling kit. http://www.summitracing.com/parts.aspx?sku=HCK-WFBR6
or
Eastwood Company
http://www.eastwood.com/metal-fabric...ad-roller.html
Old Nov 1, 2009 | 07:02 PM
Car: 1985 Camaro
Engine: 2.8l
Axle/Gears: Stock
thanks, im going to be getting the pan bead rolled tomorrow
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
LC2 TECH
Oct 13, 2015 11:53 PM
88CamZ
Oct 8, 2015 10:29 AM
loud91rs
Oct 5, 2015 10:05 PM
skinny z
Oct 5, 2015 06:23 PM
