Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
plasma cutter owners inside please
Old Nov 14, 2009 | 06:51 PM
TIMMYS89GTA's Avatar
Car: 81z-28,89gta,91z-28 03 1500
Engine: 355,L98vette tpi,327
Transmission: TH350/700R4/700r4/4l80E
Axle/Gears: 3;73/3;27/2;73/3;73
been browsing a few,ready to buy and just curious if anyone happens to know how much electricity they burn.
Old Nov 14, 2009 | 07:02 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: plasma cutter owners inside please
Depends what type you buy and what voltage you run it off of. I purchased a Miller 375 for the last shop I worked at. Running it off 110v, it needs a minimum of a 20amp breaker.
You also need a good air supply so the electricity of an air compressor needs to be included. The 375 needs a minimum of 4.5 CFM at 90 PSI.
Old Nov 18, 2009 | 01:21 PM
oil pan 4's Avatar
Car: 89 Firebird
You want to know how much power it takes to support running them or how much they add to your power bill?
I have a miller 625 and with out counting the power the air compressors need the plasma cutter alone uses slightly more power than a home clothes dryer when turned up to full power.
Old Nov 18, 2009 | 01:48 PM
87tpiz28's Avatar
Car: 1987 z28
Engine: 305tpi
Axle/Gears: 2.73 posi
Amps X Volts= watts. given stephen's 110v at 20amp thats 110X20= 2200watts
now my bill comes by killowatt hours. so kilo=1000. therefore 2200/1000= 2.2kilowatts
and they charge about 10 cents per kilo watt hour, so using the plasma for one hour would be roughly 10X2.2= 22 cents. cheap, but adds up fast!
PurelyPMD
May 5, 2016 04:57 PM
75bike
Sep 20, 2015 09:37 PM
sandman92084
Sep 12, 2015 10:27 PM
Fronzizzle
Sep 8, 2015 12:10 PM
84 TA NV
Sep 6, 2015 08:02 PM
