Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Mid-engine Third Gen?
Old Aug 23, 2011 | 01:07 PM
  #101
Thirdgen89GTA's Avatar
Car: 1989 Trans Am GTA
Transmission: M28 T56
Re: Mid-engine Third Gen?
There may be a video of it leaving thirdgen fest from 2010. But I'm not sure, I will look.
Old Aug 23, 2011 | 01:09 PM
  #102
Indeed there is. its not a true WOT clip. But you can get a sense of the sound from that.
http://www.youtube.com/user/gearhead...25/sCMeiRFlNow
Old Aug 23, 2011 | 01:17 PM
  #103
gsmarcano's Avatar
Car: Camaro
Engine: 350-Vortec-carbed
Transmission: 700-r4
Axle/Gears: stockola, right now anyhow
Originally Posted by duckmanquacker
umm WOW!!!!
Old Aug 24, 2011 | 08:22 AM
  #104
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
don't know how I missed this thread for so long, but beautiful job on that bird. its not too often you see something so original done to these cars and done well!
Old Sep 22, 2011 | 01:51 AM
  #105
RSFreak's Avatar
Car: 1985 Camaro, 1986 Trans Am
Engine: 5.0L carbed and 5.0L TPI
Transmission: TH700R4
Axle/Gears: 3.23 and 3.27 posi
Originally Posted by 25thAnn_RS
I agree with all things are possable with time and money. Here is an interesting rear engine Camaro, with the motor out of a Subaru. I know it's not a third gen, but it is possible. Although this car was designed to float.
Wow! Someone figured out how to make 4thgens even uglier!
Old Sep 29, 2011 | 11:18 AM
  #106
86sc5's Avatar
Car: 86 sport coupe
Engine: 355
Transmission: 5speed
Axle/Gears: 3.73 detroit locker
Originally Posted by AlkyIROC
An Olds Toronado or Caddy Eldorado would be good choices for transaxles. They would be more compact than the Vette system in the above picture.
1978 HotRod magazine did a story on a mid engine Olds 442. Information is available online. I still have the issue around here somewhere.
http://www.hotrodharrys.com/cars/sho...hp?articleID=3
http://www.hotrodharrys.com/cars/sho...hp?articleID=4
Dave Wolcott, a good friend of my uncles owned this car back in the early 90's. I have rode in this car a few times and it is a blast. Back then it was black with teal and pink stripes.
Old Sep 29, 2011 | 12:11 PM
  #107
The mid engine bird I posted above also uses the Toronado trans.
Old Sep 30, 2011 | 10:16 AM
  #108
micktroup2's Avatar
Car: 1991 Z28
Engine: 5.7 TPI
Penelope's car from Thunderbirds? Seriously AlkiIroc, you need to get out more, LOL! The Elf Tyrrell Grand Prix car had 4 front wheels too...
GM made a rear engined Camaro- it's called a Fiero. I would swap a small block or 3.4 into one of those before I would cut up a 3rd Gen. But if you have unlimited time and budget... I have a burnt out 1991 you can have cheap as a project car!
Old Sep 30, 2011 | 12:01 PM
  #109
Its not your car, its his. If its done right its not "cutting up" and ruining a thirdgen. Its using a thirdgen to build another project car as has been done many times in the past.
Old Jan 16, 2012 | 11:40 PM
  #110
Mirror Image's Avatar
Car: 1991 Firebird convertible
Engine: LQ4 ls 6.0
Axle/Gears: 342 Limited slip
here is one that came out in i think it was car craft years ago it is a 68 camaro it has a mid engine olds 455 you cant tell it by the picture in car craft there were more photos here is what i have
Attached Thumbnails Mid-engine Third Gen?-camaero.jpg   Mid-engine Third Gen?-camaero2.jpg
Old Jan 17, 2012 | 12:23 AM
  #111
streetpro's Avatar
Car: 1987
Engine: 454
Easy to do if you have two or three years,thats an olds 425 engine,transaxil from 1967 Olds Toronado,the caddy setup will work also.I would buy a practice third gen from craigslist do not ruin your car, This way you can see if it can be made to fit and roll straight.buy a running caddy,pull the running gear,and all parts needed to run and stop.then all it takes is two or three skilled guys and a deep wallet and you will have a mid engine camaro.
Old Jan 17, 2012 | 12:43 AM
  #112
lmidden's Avatar
Car: 1987 camaro sc
Engine: lg4 305
way to bring back an old post but i believed a mid engine is quite possible ive been thinking of it the last coupe days i thought it would be possible if you took the engine/trans out of a police impala 2000-2005 (215hp) and make up a frame to hold it after cutting apart the rear end out basicly. then wire it up. welding a sheet of steel in the old engine bay to make a trunk having the front slant down to the ground from the rad suppot so the air can escape. cooling would be 2 2in pipes goin down the tunnel the gas tank would either be in the front or behind the engine. electric cooling fans. take another sheet or 2 to make a fire wall and wheel wells. taking the stock exhaustmanifold adding a flex joint so when the engine moves from torque then running it to a muffler that goes across the back bottom of the car.taking a shifter from a shifter from an impala with a console so it will still be floor mounted. run a tube for intake down the tunnel put the air box in like the location of the charcoal canister.
Old Jan 17, 2012 | 12:45 AM
  #113
streetpro's Avatar
Car: 1987
Engine: 454
it could be done just not sure with out using the tube frame,there is a pic of one already posted.
Old Jan 17, 2012 | 12:58 AM
  #114
lmidden's Avatar
Car: 1987 camaro sc
Engine: lg4 305
i just saw that but that could not have been cheap to build
Old Feb 18, 2012 | 09:31 PM
  #115
morrow's Avatar
Car: 92 Camaro Rs.R
Transmission: wc t-5
your going to need to shorten the front and extend the rear, my uncle and i are building a c4 based super car that is now mid engine, set up for an ls7 with a Porsche trans axle and 180 deg headers . the front got shortened 10 inches and lengthened 20 in the rear, with engine and driver the bias is 50 50
Old Feb 19, 2012 | 03:58 PM
  #116
zenish's Avatar
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
i used to have a 500 caddy engine in a chevy pickup.the 1970 500 engine was factory rated at 400 bhp.if you use an edelbrock intake on the 500,it weighs less than 100 pounds more than a 350 chevy.id use a 500 and transaxle out of a early seventies eldelrado.
Hotrodboba400
Dec 10, 2019 07:07 PM
nugentcj
Camaros Wanted
Dec 22, 2015 02:58 PM
Stryker412
Sep 7, 2015 09:11 AM
Vassago
Convertibles
Sep 4, 2015 09:37 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
