Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
fuel pump hole
Old Jan 25, 2010 | 08:48 PM
fazt4life's Avatar
Car: 1991 camaro z28
Engine: 5.7 350
Axle/Gears: stock 3.23
fuel pump hole
ive been reading all over this site about the fuel pump access hole. well my fuel pump crapped out and i do not have the tools or time required to drop the axle remove the exhaust etc etc. so i decided to go ahead and try out the access hole. it worked out great. all i did was mark it up and cut out the section with a 4 1/2 cutoff wheel. able to replace the pump in about an hour. anyone could do this at home as an easy alternative to dropping the tank or taking it to a shop.
the picture i have is of it almost done i just need to get some more hose then make a gasket and a plate to cover the hole. highly recommended by me. thanks to everyone who helped me out on this one.
Old Jan 27, 2010 | 09:01 AM
Pocket's Avatar
Car: 91 Trans Am
Re: fuel pump hole
The downside is cutting your fuel lines. Carb and TBI guys dont care because they operate at a very low pressure
V6/TPI/LT1/LS1 owners risk blowing out the rubber lines or common compression clamp
Most people never have a problem, but the risk will always be there
Old Feb 6, 2010 | 06:01 PM
TTA579's Avatar
Car: Turbo Trans Am #579
Engine: 231ci (3.8L) LC2 (Buick Turbo)
Transmission: 200r4
Axle/Gears: Borg-Warner 9-bolt
Re: fuel pump hole
With a little consideration, some AN type fittings means no hose issues.
Old Feb 6, 2010 | 06:14 PM
chads89ta's Avatar
Car: red 89 t-top ta
Engine: 305 tpi
Transmission: t-5
Axle/Gears: 9 bolt soon
Re: fuel pump hole
if u use compression fittings it will be fine
Old Feb 6, 2010 | 07:48 PM
Pocket's Avatar
Car: 91 Trans Am
Re: fuel pump hole
AN fittings require tube sleeves and nuts with the line flared. Pretty much no one does that
Compression fittings work, but again, as the original poster shows, they are rarely used
Old Feb 6, 2010 | 08:06 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: fuel pump hole
Or a self-swaging fitting.
Old Feb 6, 2010 | 08:22 PM
Pocket's Avatar
Car: 91 Trans Am
Re: fuel pump hole
http://www.summitracing.com/parts/EAR-165056ERL/
Things like these fall under the compression fitting category and are not rated for the high pressures of EFI systems
Old Feb 6, 2010 | 08:37 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: fuel pump hole
No, not those... but even still that particular Earl's fitting is rated for up to 50 PSI, and you'll routinely find other compression type fittings in domestic plumbing at up to 120 PSI, or in hydraulic and brake systems at even higher pressure. It's a matter of choosing the correct compression fitting to match the maximum working pressure of the tubing. I'm still not a fan of compression fittings though because they require the exterior of the pipe to be free of defects, which isn't always the case on 20 year-old cars.
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
evilstuie
Jan 9, 2020 08:29 PM
mustangman65_79
Apr 14, 2017 05:37 PM
92camaroJoe
Aug 13, 2015 06:07 AM
