Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
steering box quandry
Old Mar 11, 2010 | 04:56 PM
stevek's Avatar
Car: 1989 GTA
Engine: 5.7 /360
Transmission: turbo 350
Axle/Gears: stock
The power steering return line at the steering box on an 82 Z-28 is what type of fitting and can it be replaced by something else? The local GM shop said the fitting isn't servicable(not available)so is there something at the hardsware store that will work?
Old Mar 11, 2010 | 08:48 PM
Pocket's Avatar
Car: 91 Trans Am
Re: steering box quandry
Saginaw fitting, either 16x1.5mm O-ring or 14x1.5mm O-ring. I cant remember exactly, but I think its the larger one. Same fittings as your fuel lines
Old Mar 12, 2010 | 05:43 AM
stevek's Avatar
Car: 1989 GTA
Engine: 5.7 /360
Axle/Gears: stock
Thanks for the info.
Old Mar 12, 2010 | 10:13 PM
83 Crossfire TA's Avatar
what he said, try a transmission shop or hydraulic shop. Pep boys used to carry stuff like that but the last time I was there it seemed like a lot of the more serious parts they used to carry were gone.
Old Mar 12, 2010 | 10:21 PM
chads89ta's Avatar
Car: red 89 t-top ta
Engine: 305 tpi
Transmission: t-5
Axle/Gears: 9 bolt soon
if it is the same, advance auto sells repair fuel lines with fittings
83 Crossfire TA
Jan 3, 2016 01:26 PM
bubbaz28
Sep 18, 2015 02:09 PM
punkmaster98
Sep 8, 2015 09:45 PM
83 Crossfire TA
Sep 8, 2015 12:06 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
