Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Bracketology 101
Old Mar 13, 2010 | 11:00 AM
stevek's Avatar
Car: 1989 GTA
Engine: 5.7 /360
Transmission: turbo 350
Axle/Gears: stock
Bracketology 101
I have a 350 out of a 79 truck that I have put in my 82-Z.I have all of the pulleys for both serpentine and V-belts but none of the brackets. Can I buy any brackets off any V-8 Chevy car ? I only want to run an alternator,water pump and power steering pump.
Old Mar 13, 2010 | 12:08 PM
Pocket's Avatar
Car: 91 Trans Am
Re: Bracketology 101
Serp brackets wont help you much since they only work as a group. You're not using half the pulleys and the idler, so making something work would be a job in itself
Id go with a low mount V belt setup. Check summit or jegs. Youd need to change the waterpump though, good thing they are cheap
Old Mar 13, 2010 | 12:33 PM
Stephen's Avatar
Car: 87 GTA
No. Not all brackets will work on all chassis.
For example....Corvette brackets tend to sit the accessories up higher than a truck, because of chassis interference issues. Trucks have more room lower down, so they can do that. Corvettes can't.
Same with 3rd gens. Corvette accessory brackets won't work in F-bodies either. You'll hafta find 3rd gen brackets.
Old Mar 13, 2010 | 01:37 PM
dellman83Z's Avatar
Car: 87 monte aerocoupe
Engine: 383 HSR w/ novi 2000
Transmission: Built 4l80e circle d converter
Axle/Gears: Currie 9" 3.89 gears
I just ordered some brackets from summit(their brand) for both the alt and ps pump. I have seen them on another car and they look and fit great. Just do a search on their website and they pop right up.
Old Mar 13, 2010 | 01:59 PM
stevek's Avatar
Car: 1989 GTA
Engine: 5.7 /360
Axle/Gears: stock
I just figured on going to the salvage yard and pulling the brackets off an older Caprice or similar car with a V-8
TRAXION
Dec 7, 2002 03:23 PM
HighHopes85
Dec 12, 2001 11:04 PM
Birmass
Sep 8, 2001 11:30 PM
Willie
Jun 13, 2001 12:24 AM
Gta-Paladin
May 27, 2001 11:32 PM
