Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
1/2 fuel lines
Old Mar 13, 2010 | 12:30 PM
v8 drift's Avatar
Car: 84 Z28
Engine: 355
Transmission: t56
Axle/Gears: 4 11
1/2 fuel lines
i was wondering if anyone out there has ever customized there tank pick up to run 1/2 lines i plan on going with 2 seperate fuel systems 1 for daily driving and the second for my nitrous on the weekend so i will need 2 new lines into the tank also would i need a half inch return im going to run a pump a bit bigger then i need rite now im close to 450 hp on the engine and 150 shot of nitrous
Old Mar 13, 2010 | 10:52 PM
built91Z28's Avatar
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
Re: 1/2 fuel lines
I'm running 1/2" hard line to -8AN braided. I sumped my tank though with the return line going in to the tank up high but not completely on top.
Old Mar 14, 2010 | 05:50 PM
tom86iroc's Avatar
Car: 1986 iroc
Engine: alum. head 350 supercharged
Transmission: 6speed
Axle/Gears: ford 9in 3.90 35 spline moser axles
Re: 1/2 fuel lines
not the factory pickup i added an #8 to the back of the tank and added a #8 right beside the filler neck for return
Old Mar 17, 2010 | 08:18 AM
101btp's Avatar
Car: 86 Trans am
Engine: workin on a 383 for it!
Re: 1/2 fuel lines
can you if you have a mechanical pump just run a disturbution block off the pump one for the carb the other for the nos?
Old Mar 17, 2010 | 09:30 PM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
Re: 1/2 fuel lines
very doubtful that any mechanical pump will supply enough fuel volume for both the nitrous and carb.
Old Apr 14, 2010 | 01:35 PM
83 Crossfire TA's Avatar
Re: 1/2 fuel lines
http://www.summitracing.com/parts/RPU-1600/
Old Apr 14, 2010 | 04:20 PM
mw66nova's Avatar
Engine: 7.0L
Re: 1/2 fuel lines
Originally Posted by 83 Crossfire TA
i know of nobody running that particular pump with any real success.
Frozer!!!
Jan 19, 2024 04:55 PM
theshackle
Mar 5, 2017 06:37 PM
Andrew6.688
Dec 13, 2015 10:59 AM
AkDrifted
Aug 17, 2015 07:45 PM
