Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Custom 1LE bracing
Old Mar 25, 2010 | 11:09 AM
MADMAXGTA's Avatar
Car: 89 TTA
Custom 1LE bracing
Got this idea after looking at my a few pieces of a edelbrock strutower brace,whatcha think? go for it? there is existing bolts where they meet the fender.Ill have to bend the tabs of the bars for a perfect fit.
mock up pics
http://img691.imageshack.us/i/bracing001.jpg/
http://img127.imageshack.us/i/bracing002.jpg/
http://img148.imageshack.us/i/bracing003.jpg/
Old Mar 25, 2010 | 06:41 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Custom 1LE bracing
interesting, wonder if they will make a difference or not?
Old Mar 25, 2010 | 08:08 PM
MADMAXGTA's Avatar
Car: 89 TTA
IDK,but it looks neat,lol.
Old Mar 25, 2010 | 08:29 PM
383fbod's Avatar
Car: 88 IROC-Z
Engine: 383
Axle/Gears: 4th gen 3.42posi
Now thats thinking outside the box
Every little bit helps. placebo or not.
Old Mar 25, 2010 | 08:31 PM
Stephen's Avatar
Car: 87 GTA
Dunno why you called them '1LE'. I've seen those THIN stock ones before on non-1LEs. IIRC, my wife's 90 RS 305 TBI had them. Probably the reason why they were dropped, was because they did nothing but add build cost to the cars.
Old Mar 25, 2010 | 08:33 PM
MADMAXGTA's Avatar
Car: 89 TTA
I called it 1LE cause i thought it was a standard feature with all 1LEs.
Old Mar 25, 2010 | 08:51 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
At least some Camaros were equipped with the BRACE, Fdr to Upr Cowl (GM 14074745) from 82-91, according to my Part & Illustration Cat.
JamesC
Old Mar 25, 2010 | 11:42 PM
92RS(real slow)'s Avatar
Car: 92 RS(sold) 1989 IROC-Z
Axle/Gears: ones that turn
ive had them on both of my camaros
Old Mar 27, 2010 | 11:36 AM
racing geek's Avatar
Car: 1987 IROC-Z
Engine: 383 with Edelbrock ProFlow EFI
Transmission: TH350
Axle/Gears: 12 bolt 3.73 Eaton posi
I can't remember the name, but there was another thread where these were discussed and if I remember correctly, the conclusion was that those braces don't do much of anything for stiffening when referring to performance. You're just bracing the fender/hood support mount to the cowl.
Old Mar 27, 2010 | 11:38 AM
MADMAXGTA's Avatar
Car: 89 TTA
Yea thats pretty much what I thought,but I had to ask,looks neat but just adds weight.
Old Apr 1, 2010 | 11:22 PM
ATX-Iroc's Avatar
Car: 87 Iroc-Z
Engine: 305 tpi
Transmission: 700-r4
My iroc got's one of those braces on the passenger side but not the driver, probably P.O. syndrome. An interesting note is that i can see scratches on the wheel well from the bolt that holds the bar on the fender, it's about a half inch gap I cant believe it would flex that far.
Old Apr 2, 2010 | 06:41 AM
JamesC's Avatar
The piece appears on the pass side only.
JamesC
Old Apr 2, 2010 | 05:42 PM
ATX-Iroc's Avatar
Car: 87 Iroc-Z
Engine: 305 tpi
Ok i didnt get that he was making an extra for the driver side i thought he was just asking about them. Since were on the subject, did all cars get the brace from the pass. frame rail to the strut tower? I wonder why gm put three braces on the pass. side and none on the driver. To the O.P. those look nice a lot bigger than the tooth picks these cars came with. You did make the passenger side one bigger and move the mounts right.
Old Apr 2, 2010 | 05:44 PM
MADMAXGTA's Avatar
Car: 89 TTA
I havnt mounted them,I was just considering it,they are equal length.
Old Apr 2, 2010 | 08:56 PM
JamesC's Avatar
This piece, Brace, Whl Hse Pnl reinf-RH (Z28), is also listed 82-91. Though the Z28 business is only listed 82-86, the part number is the same for all years, 14045394.
JamesC
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
dusterbd
Sep 29, 2015 08:40 AM
