Covering TPI aircleaner with carbon fiber sheet.
I poked around and saw some people making custom intakes out of cf or fiberglass, but didn't find anything on covering the stock intake with cf sheeting. I have seen someone somewhere cover a TPI intake/runners with CF and I'm just wondering if anyone's had much experience with this stuff, can I heat it with a heat gun to get it to conform better? I'm planning on doing this because my aircleaner lid is all looking pretty bad, and I'd like to spruce it up a little. Any input greatly appreciated guys! Thanks
Will
Will
1 Post
Car: 1987 IROC-Z
Engine: 383 with Edelbrock ProFlow EFI
Transmission: TH350
Axle/Gears: 12 bolt 3.73 Eaton posi
Re: Covering TPI aircleaner with carbon fiber sheet.
You can't heat up carbon fiber or fiberglass to bend it.
1 Post
Car: 1987 IROC-Z
Transmission: TH350
So it's like a giant sticker? Yeah, you should be able to heat it a little to form it around some curves just don't get carried away with it because it will stretch the pattern or leave ripple that you won't be able to get out. To get the sticker to stick to the intake it will have to be really smooth. Have you already sanded down the intake to get rid of the grainy cast finish?
I don't know how much you want to spend but I know there are companies that will coat various things in different patterns such as carbon fiber. I can't remember what it's called, but they suspend this pattern almost like a liquid wallpaper in water and then push the part down into the pool of water and the patern pulls itself over the part. As long as there are no cut backs in the part they should be able to coat it. I've seen the stuff in person and it looks really neat. I was talking with a guy that had it done on his '01 SS and he maid it sound like the price wasn't bad either. I have pictures of the parts he had coated somewhere on my computer...
Car: 87 GTA
Transmission: soon to be t56
Axle/Gears: 3.73 posi
3m has a product called di noc or something to that effect, but supposedly is actually textured and looks way better than the normal vinyl stuff. Anyway, that can be heated with a heat gun and such, people have done all kinds of stuff with it, if you look it up there is a lot of documentation on using it for various applications.
1 Post
Car: 1987 IROC-Z
Transmission: TH350
That's what I was talking about. Thanks for the link.
Car: 87 GTA
You can buy carbon fiber patterned vinyl (sticker material) from Oracal & it'll work perfectly fine on an air lid. Go to your local sign shop & they can either cut it out for you, in whatever patter/design/lettering you need, or sell you a sheet that you can use to overlay & trim to fit.
I cut out some & tested a flame cut out piece directly on the intake plenum, expecting the engine heat to cause it to blister & peel. Also did WS6 lettering on the air box....Nothing ever happened to it either. It never did.
I've been doing signs, from simple lettering on windows to billboards, to electrical neon lettering for almost 15 years.....I pretty much knew it would be fine, just wasn't positive, it being directly on the under hood heat of a car, but it was.
1 Post
Car: 89 iroc
Engine: 355 TPI FINALLY
Transmission: 700r4/ SHIFT KIT
stickers are just that "STICKERS"........ your not going to be able to get all the nicks and cranny's with overlay...just my opinion
Yea I hear what you're saying, and if you want to send me 250 to get it hydro-dipped or whatever, I'll gladly do it. But 10 bucks for a 2x5 sheet of this stuff to try myself, that seems better for a first attempt.
1 Post
Car: 89 iroc
I agree I was thinking the same way...........I'm thinking winter project myself, and see how I like the vinyl first.....and see what kind of response we get from the vinyl.
Car: 87 GTA
I have the original CF design on my dash, console & my door handles.....
And had it on my center caps, until I got replacement OEM emblems from ROH.
Absolutely NONE of that has ever peeled, blistered or nothing. You can now get the diagonal stripe design CF vinyl too.
ambainb
04-25-2016 09:21 PM
NBrehm
08-25-2015 11:49 PM
Sanjay
08-12-2015 03:41 PM
