Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Hatch Louvers
Old Apr 19, 2010 | 11:41 AM
vengetta82's Avatar
Car: 1982 Camaro Berlinetta
Engine: LG4
Transmission: One that shifts hella hard
Hatch Louvers
has anyone made a bracket to hold on louvers to the top of the window? mine doesnt have any, just the little clips on the sides... i was wondering how hard they wold be to make and what they should look like
Old May 22, 2010 | 09:31 PM
rshumaker's Avatar
Car: 1991 Camaro Z28
Engine: 5.7L 350 L98
Re: Hatch Louvers
Vengetta82, I see this post is a bit dated, but thought I'd chime in. I just completed making one bracket for my louvers. Fortunately, I had one to use for reference so I just needed to build the second. It only cost: $7 for a sheet of 22 gauge steel from Home Dept, and $1 for a package of 3/4" length bolts. Used a handful of tools to build: dremel to cut the piece from the metal sheet, vice to hold the metal, vice grips to bend and a hammer and metal punch to shape it into place, and a drill. I did end up case hardening the metal with oxy torch and dipping in oil. 1 1/2 hours later, I had a complete bracket.
Can send pics if you are still looking for a solution and need to see a bracket for reference.
Old May 24, 2010 | 11:18 AM
vengetta82's Avatar
Engine: LG4
Re: Hatch Louvers
yeah i ended up doing about the same thing... i grabbed some 18 gauge from school and made some brackets and bolted them on so i could remove the louvers if need be. i didn't do the oxi torch and oil dip though.... i would like to see some pics though!
jrdturbo
Mar 31, 2016 02:58 PM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
formula00ra
Sep 28, 2015 11:50 AM
disjaukifa
Exterior Parts for Sale
Sep 16, 2015 09:39 AM
