Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Scratch Filler
Old Apr 22, 2010 | 08:42 PM
Timinsk's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
Scratch Filler
I have a cluster of scratches on my driver side window which i'd rather fill in, but i don't know of any glass scratch filler. Curious if anyone else knows? I'd love to replace the glass but i don't know how and rather not fiddle and screw up the glass with riveting it to hard it breaks...
Old Apr 22, 2010 | 10:45 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Re: Scratch Filler
Theres not really anything you can do to 'remove' scratches from glass, like you can paint or plastic. When one uses a polish on paint or plastic, for example, that polish does not remove the scratch, it just gets into the scratch and polishes the inside of the scratch to make it match whats around it - making it appear to vanish. This works reasonably well on paint and clear plastics (think headlights) but it doesn`t work on glass very well.
Old Apr 23, 2010 | 12:14 AM
Timinsk's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
Re: Scratch Filler
Thats why i'm asking about a "filler", i was debating on using a deluted epoxy, and then just keep rubbing it in the area in small patches..
I have power locks, non-power windows so i dont know the process of exchanging a driver side window on the door... unless someone has a guide?
Old Apr 24, 2010 | 11:32 PM
83 Crossfire TA's Avatar
Re: Scratch Filler
the windshield repair kits use a UV setting resin that have refractive qualities very similar to glass, so when you fill glass with it it mostly disapears, but I've never tried it on scratches or side glass.
Old Apr 25, 2010 | 12:52 AM
grassyflats's Avatar
Re: Scratch Filler
that is the solution I need
and a very good idea...
Old Apr 25, 2010 | 07:24 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Scratch Filler
The side windows seem given to scratches. I wonder if 'fixing' them, regardless of method, would be permanent.
JamesC
Old Apr 25, 2010 | 09:37 AM
Timinsk's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
Re: Scratch Filler
Thanks, what i'll do is probably get a flat rubber puddy knife and then use the "windshield repair kit epoxy" and just make a thin coat and rub it around so its not glumpy.
Old Apr 25, 2010 | 12:13 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Scratch Filler
cant the window glass be polished to remove the scratches?
Old Apr 25, 2010 | 12:24 PM
JamesC's Avatar
Re: Scratch Filler
I had a body shop buff out/polish a windshield wiper scratch, and while the scratch can't be easily seen, it's still there. Probably a bigger scratch though than would appear on a side window.
JamesC
Old Apr 25, 2010 | 02:29 PM
Timinsk's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
Re: Scratch Filler
What do you do for buffing it out? I have a rotary buffer, just don't know what to use.
Old Apr 27, 2010 | 10:29 PM
Re: Scratch Filler
I've never played with the stuff outside of it's syringe, but I'm pretty sure that the stuff is pretty thin, those kits use suction cups or stick onto the windshield and then use a vacuum to pull the stuff into the crack till it sets up with UV light (the "professional" setups are basically the same with reusable mounts and they add a UV light to cure the stuff faster).
As far as polishing, it's not uncommon for body shops to polish the crud off a windshield, but i'm pretty sure that the stuff used to polish scratches out is a much harder abrasive than normal rubbing or polishing compound. I'd love to know of something easy to get your hands on that would work.
Old May 6, 2010 | 07:13 AM
Timinsk's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
Re: Scratch Filler
http://www.caswellplating.com/buffs/glass.htm
just googled window buffer, and found quite a few things, i'd like quite a few opinions. because i don't mind purchasing this.
Old May 6, 2010 | 07:14 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
Re: Scratch Filler
Ive used Cerium powder with some success before. Its not gonna make it disappear, but it will help.
Old May 6, 2010 | 09:54 PM
Timinsk's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
Re: Scratch Filler
The way i look at it... better than nothing :P
Old May 22, 2010 | 12:11 AM
Re: Scratch Filler
where do I get some?
Old May 22, 2010 | 01:25 AM
travis401's Avatar
Car: 91 Camaro RS
Re: Scratch Filler
Most auto detailing supply stores will carry it. Its called cerium oxide.
Old May 26, 2010 | 08:32 AM
neagan's Avatar
Car: 1988 IROC 5.7 Money Pit
Engine: (being built; modified TPI ZZ4
Transmission: 2200 stall/ stage 3 700R4
Axle/Gears: freshened 3.27 in 9.bolt/
Re: Scratch Filler
I just added that to my list of automotive suppliers. With 9 vehicles, I usually end up fighting glass scratches eventually. This is a great sounding kit solution. Thanks for posting it!!! Nitro-Nicky
Eric-86sc
Feb 25, 2016 09:02 PM
86IROC112
Nov 7, 2015 06:50 AM
Bubbajones_ya
Oct 25, 2015 08:01 PM
Royal_Z
Sep 30, 2015 08:45 PM
florida_gators
Exterior Parts Wanted
Sep 7, 2015 07:19 PM
