Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Firebird gear in a 69 Chevelle
Old Jun 1, 2010 | 03:17 PM
SpeedyGeek's Avatar
Car: 87 Formula
Engine: BluePrint 355 w/ 600cfm Carb
Axle/Gears: New axles, Yukon 3.73 & Eaton Posi
So I'm wondering, will an engine, rear end, transmission and wheels from an 87 Formula fit a 68 or 69 Chevelle? I know the engine is no problem, both use Gen I GM engines.
Not interested in wiring and computer and all that. Just fitment, wheel base and bolt patterns, things like that.
Old Jun 1, 2010 | 03:49 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Firebird gear in a 69 Chevelle
the rear wont fit, the chevelle is made for leaf springs, the 3rd gen, coil springs and a torque arm. besides the stock 3rd gen axles blow big time, so why downgrade.
Old Aug 8, 2010 | 08:32 AM
85Z28NOS's Avatar
Car: 85 Camaro
Engine: 454 RamJet
Transmission: LT1/T56
Axle/Gears: 8.8w/4.10
I gutted a 89 Formula 350 and installed the TPI 350 motor,700r4,dashboard,steering column,wiring,steering box,sway bars,rims/tires,and a aluminum radiator from a 93 buick lesabre. It took some time but looks great and drives twice as good than with the original equipment. The rear end is stronger in the chevelle(8.5 compaired to 7.5) so its a waist of time. It all depends on your ability and your time and money. I had both cars and some free time so I just decided to do it. Good luck, hope this helped
Old Aug 9, 2010 | 12:06 PM
gregsz-28's Avatar
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
Chevelles have triangulated 4-link and coil springs.
junkcltr
Aug 2, 2019 11:12 PM
hectre13
Aug 26, 2015 08:17 AM
Dialed_In
Aug 20, 2015 01:45 PM
tnrednneck
Aug 13, 2015 08:57 AM
MENINBLK
Aug 5, 2015 11:58 PM
