Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
new hood
Old Sep 20, 2010 | 09:49 PM
usacamaro's Avatar
Car: 92 rs & 89rs
Transmission: auto & t5
new hood
i started this back in june but havent had time to finish it. so this weekend i got back on it . its not finished but close . i got all the dents pounded out and got the layer of filler on. i got a friend of mine helping me out and he said he could make these hoods or any kind anyone wants steel or fiberglass. soon as were done with this hood were going to start one of those infamous jap hoods. so let me know what you guys think. also about the other hoods .
Last edited by AlkyIROC; Sep 20, 2010 at 11:51 PM. Reason: pictures needed spacing
Old Sep 20, 2010 | 11:11 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Re: new hood
i think its a great start, can't wait to see it painted up. keeps the louver/blister provisions while still keeping the factory lines.
Old Sep 20, 2010 | 11:53 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: new hood
Steel and fiberglass are heavy. I want a nice lift off one out of aluminum with just enough bracing to keep it's form.
Old Sep 21, 2010 | 12:43 AM
ericjon262's Avatar
Car: 85 2M6, 87 'Bird 88 'burb
Engine: LX9, LG4, L05
Transmission: F23, 700r4, 700R4
Axle/Gears: 3.63, 2.73, 4.10
Re: new hood
Then make one.
USAcamaro, looks pretty good, can't wait to see it finished.
Old Sep 21, 2010 | 02:00 AM
gregsz-28's Avatar
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
Re: new hood
+1. I'd be interested for sure if someone made aluminum hoods for Camaros.
That hood did turn out pretty good though.
Old Sep 21, 2010 | 07:08 PM
Mathius's Avatar
Re: new hood
I think it looks great. Very aggressive looking. If you had a build thread I missed it though. I have a question.. Did you just cut and weld that cowl on, or did you try to do it factory with the inner hood panel raised as well?
I guess I'm asking if you just modified the top skin of the hood, or the bottom as well.
Mathius
Old Sep 21, 2010 | 08:12 PM
usacamaro's Avatar
Car: 92 rs & 89rs
Re: new hood
sorry no build thread i do have pics of the process just never started a build thread on it . as for the top side of the hood i cut down the body lines and raised it up about 3 1/4" and made filler panels for the side and welded them in. as for the bottom i cut out the center under where the blisters will set . i should have the top side in primer this weekend then i am going to start on the under side . i am going to smooth it out and blend all the seams from the sides to make it look like i didnt just hack it up. i will post more pics of the finishing process for everyone to see. also if you would like tto see some of the earlier pics let me know and i will post them up.
Old Sep 21, 2010 | 09:33 PM
92FBirdVert's Avatar
Car: 1992 Pontiac Firebird Convertible
Engine: 5.0 TBI
Re: new hood
once you get it painted it will look amazing!
Old Sep 22, 2010 | 12:02 AM
iroc stangs's Avatar
Car: 87 iroc-z camaro
Engine: 305TPI
Axle/Gears: G92 3.23 posi
Re: new hood
Looks good! Defintly should make the louvers functional since you already have it down to this. Looks great though!
Old Sep 22, 2010 | 09:18 AM
awilson82's Avatar
Car: '82 Camaro Z28
Engine: 383
Axle/Gears: 3.73 with powetrax
Re: new hood
Looks good kinda wish Id done mine with a Z28 hood instead of a flat one.
Old Sep 30, 2010 | 11:35 AM
tylercamaro's Avatar
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
Transmission: TH350, 4L80E
Axle/Gears: 3.42, 3.73
Re: new hood
what would it look like if you put the jap hood and mixed it with the louvered cowl one? just an idea, im indecisive
Old Jul 10, 2012 | 09:38 PM
usacamaro's Avatar
Car: 92 rs & 89rs
Re: new hood
Old Jul 10, 2012 | 10:06 PM
usacamaro's Avatar
Car: 92 rs & 89rs
Re: new hood
sence i dont have a build thread and havent posted any pics of the process here are some i never posted
here you can see where i cut the hood
Old Jul 10, 2012 | 10:07 PM
usacamaro's Avatar
Car: 92 rs & 89rs
Re: new hood
usacamaro's Avatar
Car: 92 rs & 89rs
Re: new hood
Old Jul 10, 2012 | 10:08 PM
usacamaro's Avatar
Car: 92 rs & 89rs
Re: new hood
this is the 2x4s to raise the cowl
Old Jul 10, 2012 | 10:09 PM
usacamaro's Avatar
Car: 92 rs & 89rs
Re: new hood
Old Jul 10, 2012 | 10:12 PM
usacamaro's Avatar
Car: 92 rs & 89rs
Re: new hood
started adding sides
usacamaro's Avatar
Car: 92 rs & 89rs
Re: new hood
Old Jul 10, 2012 | 10:14 PM
usacamaro's Avatar
Car: 92 rs & 89rs
Re: new hood
sides all tacked in as you can see i ran out of the 18 gauge and had to use some 22 for the very front warped alittle
Old Jul 10, 2012 | 10:16 PM
usacamaro's Avatar
Car: 92 rs & 89rs
Re: new hood
back added for more aggressive look
usacamaro's Avatar
Car: 92 rs & 89rs
Re: new hood
Old Jul 10, 2012 | 10:17 PM
usacamaro's Avatar
Car: 92 rs & 89rs
Re: new hood
underside
Old Jul 10, 2012 | 10:23 PM
usacamaro's Avatar
Car: 92 rs & 89rs
Re: new hood
i am not a pro by any means so some of the welds might not look the best but it is fully welded and very strong. the hood is all done and in primer car is taken apart and getting a couple more mods right now but will have paint soon will post pics when done.
Old Jul 10, 2012 | 10:29 PM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
Re: new hood
Looks like the build process was very much like the FYRCHKN build process.
Old Jul 10, 2012 | 10:42 PM
camaro1122's Avatar
Car: 1991 Camaro Z28
Engine: 5.0 LB9 TPI
Axle/Gears: 2.73 posi drum
Re: new hood
Great job, now i understand how you cut it. You cut the middle out of the taped part, correct?
Old Jul 10, 2012 | 10:44 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Re: new hood
After cutting out much of the underside structure, is the hood still relatively stable. I guess the cowl fabrication adds back some rigidity.
Old Jul 11, 2012 | 03:32 PM
usacamaro's Avatar
Car: 92 rs & 89rs
Re: new hood
yup cut out the middle of the tape lines and it is very sturdy prob a little more sturdy than stock because of the cowl aera
Old Jul 24, 2012 | 04:21 PM
camaro1122's Avatar
Engine: 5.0 LB9 TPI
Re: new hood
I have a few more questions, when you welded the hood up, what wire thickness did you use? Also did you completely weld everything or did you just tack it? And how did you get it the seems so smooth?
Old Jul 24, 2012 | 07:19 PM
Blownz28man's Avatar
Car: 92 25th anv z28
Engine: 346 TC78 Turbo
Transmission: 4L80E
Axle/Gears: 3.25 9"Nodular, Strange axles
Re: new hood
Looks good. Always curious what the Jongbloed hood wood look like it the z28 form. Slap some good blisters in it!
Old Jul 24, 2012 | 09:00 PM
BumpaD82's Avatar
Car: 1982 Z28 & 1967 RS & 2002 Z28
Engine: 388 ci SB / 454 ci BB / LS1
Transmission: 4 speed / TH350 / T56
Axle/Gears: '91 "1LE" rear, posi w/ 3.23's
Re: new hood
SWEET IDEA ! I can't wait for the finished prpject pics
~DaVe
Old Jul 26, 2012 | 03:03 PM
Camaro-Drew's Avatar
Car: 92 rs Camaro
Engine: no engine now, some sorta sbc soon!
Transmission: none now, built auto oneday!
Axle/Gears: stock now, 9" one day!!
Re: new hood
part of my job at work is torching and welding, so I love seing metal fab projects......this hood is pretty awesome.....can't wait till its painted!!!!
Old Jul 26, 2012 | 08:19 PM
usacamaro's Avatar
Car: 92 rs & 89rs
Re: new hood
dont think i posted a pic of it in primer yet
usacamaro's Avatar
Car: 92 rs & 89rs
Re: new hood
without the blisters
Old Jul 26, 2012 | 08:25 PM
usacamaro's Avatar
Car: 92 rs & 89rs
Re: new hood
might be a little longer for finished pics i have the car torn apart right now for full paint along with some mods
bmw headlights already done
caddy door handles
shaved antenna
shaved front turn signals
shaved front bumper and rear bumper
shaved side skirts
also i am thinking on making my own sfc while i am at it cant be to hard i made the stb. i am not by any means a pro at any of this most of this is my first time so its a learning exp. so i am kinda of taking it a little slow
heres a pic of how the car sits right now the shell is all down to bare metal getting ready for primer
Old Jul 29, 2012 | 04:47 AM
bigdavesiroc's Avatar
Car: 87 iroc
Engine: 410 sbc
Transmission: tremec 3550
Axle/Gears: 30 spline 3.73
Re: new hood
i like the hood. should be sweet when all done.
Old Jul 29, 2012 | 01:47 PM
LivinLarge's Avatar
Re: new hood
Pretty cool idea.. Anxious to see what your car looks like complete..
Old May 9, 2013 | 11:02 AM
KFCCASEY's Avatar
Car: '92 Camaro
Engine: 305 HO
Transmission: N/A
Axle/Gears: N/A
Re: new hood
What headlight conversion is that?!
Old May 9, 2013 | 08:53 PM
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
Re: new hood
bmw headlights
Old May 10, 2013 | 02:07 PM
BigKeg's Avatar
Car: 87 Black Irocz28
Transmission: 700r4 shift kit
Axle/Gears: 3:73 richmend axles and eaton gears
Re: new hood
I had my iroc shaved...front blinkers, antenna, door locks, handles, and mirror holes...
I have pics on my profile. .
You said you shaved the front bumper ...what did you shave from it ???
Old May 10, 2013 | 03:21 PM
Richboll's Avatar
Car: 89 Black IROC-Z convertible
Engine: 305 TBI
Re: new hood
How hard was the headlight conversion? It looks pretty slick. Is the hood done yet?
Old May 12, 2013 | 10:06 PM
  #42
broke91firebird's Avatar
Car: 1991 Pontiac Firebird convertible
Engine: 3.1 soon to be 3.4/3100
Axle/Gears: original gears, for now
Re: new hood
That hood is freaking sweet!!! Side note, what exactly is a "shaved bumper"?
Hopefully you can get more pics up soon of the car assembled more to show off your skills!!
Old May 13, 2013 | 05:17 PM
  #43
m grasso's Avatar
Re: new hood
sweet
Old May 21, 2013 | 04:51 PM
  #44
91ORANGEZ28's Avatar
Car: 1985 Z28/ IROC-Z
Engine: 5.0 TPI
Transmission: T-56 Magnum F
Re: new hood
looking forward to the end reveal.... i always wondered what a cowl hood with the blisters would look... A shaved rear bumper would be nice on these cars too cant wait to see how that works out too..
Old May 21, 2013 | 04:59 PM
  #45
Richboll's Avatar
Engine: 305 TBI
Re: new hood
It's been quite awhile since the OP updated. I'd really like to see it finished. It was looking great.
Old May 23, 2013 | 06:56 PM
  #46
usacamaro's Avatar
Car: 92 rs & 89rs
Re: new hood
sorry not finished yet so no updated pics . i pretty much doing everything by myself and i really not sure how to do everything so its kinda of a learning exp. i took a break from the car to repaint my work truck kinda to get the feel of painting before i paint the car . truck will be finished soon so i will be back on the car.
Old May 24, 2013 | 02:28 AM
  #47
86_irocz-28's Avatar
Car: 86 Iroc-Z28
Engine: 5.3
Transmission: 4l60
Re: new hood
Shaved or "smoothed" bumper
Side skirts
Dont mean to hijack usa great looking hood and car man!!
Old May 24, 2013 | 05:33 AM
  #48
Re: new hood
Side skirts
should have realized that, lol. Thanks that looks sweet. Following this post very closely, hoping to do my own swap this winter.
Old Jun 12, 2013 | 01:09 PM
  #49
IROC-Z123's Avatar
Car: 88 iroc-z
Engine: 350 tpi
Re: new hood
that is so cool! i thought about doing something like that. im glad it worked out. id like to see more pics when its painted
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
91TTOPZ
Exterior Parts for Sale
Sep 20, 2016 12:42 PM
