Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Installing a Cup Holder
Old Oct 5, 2010 | 12:59 AM
debo_82z's Avatar
Car: 1982 Camaro Z28
Engine: 5.7L 350 V8
Transmission: TH-700R4
Axle/Gears: 10 Bolt - 3.73
I was thinking about somehow fabricating or installing a cup holder from another Chevy vehicle into my Z28 due to it being nearly impossible to drive and have a drink without spilling. Any suggestions on how to do build and install one? Or perhaps on installing another GM vehicle's cup holder?
-Derek Boehringer
Old Oct 5, 2010 | 05:51 AM
CaliChevyLover's Avatar
Car: 1986 IROC-Z28
Re: Installing a Cup Holder
try searching the interior section... might find some good results. some people have used generic cupholders from walmart or ones from other cars with cool results. good luck to you!
Old Oct 5, 2010 | 09:42 AM
blackbmagic's Avatar
Car: 1985 IROC-Z
Engine: 355
Axle/Gears: 3.42 10 Bolt Posi
Do this behind the window/hatch controls. Most simple mod you will ever do to your car.
Step one -Walmart/ebay/autozone get a black plastic universal cup holder insert.
Step two - hole saw attached to drill. Same size as base of cup holder insert.
Step three - plastic epoxy around the edge of cup holder lip.
Step four - Insert cup holder and let dry.
Old Oct 5, 2010 | 10:23 AM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
Here's the thread I made on my cupholder install:
https://www.thirdgen.org/forums/inte...r-install.html
Here's another one, similar idea:
https://www.thirdgen.org/forums/fabr...cupholder.html
Old Oct 13, 2010 | 01:24 PM
debo_82z's Avatar
Engine: 5.7L 350 V8
Thanks for the help. I am going to look into trying this in my camaro. would it be screwed into the dash pad? I just replace my sun damaged cracked one and would rather not put screws into the new (although junkyard new) one
Old Oct 13, 2010 | 04:11 PM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
No, you don't need to put any screws in the dash pad. I did put 2 screws in from the bottom on the vent area. in the other thread, he put them into the plastic of the dash under the dash pad, but not long enough to go into the pad itself.
Old Oct 14, 2010 | 04:16 PM
90vertiroc's Avatar
Car: 1990 IROC vert
Transmission: 700-R4
-Derek Boehringer
IMO this tech article is best option: https://www.thirdgen.org/cupholder
Shiter plates are realtively cheap (less than $50 on ebay) if you dont want to cut on the original, or decide you dont like it and want to switch back there is no visable damage done. Only issue I see is you might have to move your drink to mess with the radio, but no big deal.
Vintageracer
Jan 10, 2020 05:33 PM
redmaroz
Apr 25, 2017 07:14 AM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
gixxer92
Sep 1, 2015 04:32 PM
mustangman65_79
Aug 13, 2015 07:36 AM
