Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Center Console Gauges
Old Oct 16, 2010 | 07:57 PM
P-ROC's Avatar
Car: 86 IROC-Z28
Engine: LB9
When I bought my car it came with the A-Pillar gauges. Never being a fan, I decided to make console gauge to give the car a retro look. A friend of mine used an extra center console plate that I got from the local yard. He cut out the pieces needed from sheet metal.
Here is is final product from the machine shop in the raw:
From the side
Took some grinding and cutting to get it to fit right. Here is the the final fit for the console.
The only thing left was to cut the center hole for the shifter and grind out the holes for the gauges because the sunpro gauge my buddy used to cut it was not as deep as the autometer gauges that I have for it. Final pics after fitting gauges and shifter.
This is where I am at so far. He made the edges rounded, I am thinking of squaring them out to match the squared edges of the console. Once I decide that I am completely happy with it I am going to hit it with some textured paint for a perfect match. Overall it came out great, I am just a perfectionist when it comes to my cars so it has to look like a factory option for me.
Old Oct 16, 2010 | 08:01 PM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
Re: Center Console Gauges
Well, the link info looks good & I'm sure the gauges look better, but the links aren't working, or is it just me??
Old Oct 16, 2010 | 08:15 PM
P-ROC's Avatar
Car: 86 IROC-Z28
Engine: LB9
Sorry bout that. Should be working now.
Old Oct 16, 2010 | 08:32 PM
Car: '87 Camaro
IMHO that does look real nice!!
Old Oct 16, 2010 | 08:45 PM
P-ROC's Avatar
Car: 86 IROC-Z28
Engine: LB9
The best part is that it is all separate pieces so I can change and modify it however I want. I just replace the top shifter plate with another piece of metal and cut it to fit whatever. My buddy also said he could make the front where the gauges are for anything anyone could come up with... ipods, cellphones, whatever.
Old Oct 16, 2010 | 08:58 PM
Car: '87 Camaro
I was thinking about something for the iPhone other than the ashtray too.
There's plenty room for hi-temp & oil pressure warning lights, shift light, N2O switch, etc., just has to be planned out what you may want to add, if anything in the future.
Did you use 2 5/8 or 2 1/16 gauges?
Old Oct 16, 2010 | 09:10 PM
Bonez92's Avatar
Car: '89 firebird formula
Engine: 305 TBI 5.0
Transmission: T-5 5 speed
Axle/Gears: factory
thats a pretty good idea, i might try this myself if you dont mind
although id make it to where the gauges are tilted to point toward the driver
Old Oct 16, 2010 | 09:14 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
I like it, for things you don't need to keep your eyes on all the time. Too bad you couldn't fit 4 of them in there for even more of a retro look.
Old Oct 16, 2010 | 09:33 PM
P-ROC's Avatar
Car: 86 IROC-Z28
Engine: LB9
I used the 2 5/8 gauges.
Go for it. I thought about the same thing but I can see these pretty good already when the car is in drive. In park, the right side is blocked. I also thought about recessing the front of the gauges so they are a little lower. Still may do that. At this point it's real easy to modify.
Thanks, I thought about 4 but it wasn't happening. I also would have liked to have found some rectangular gauges that would look closer to the old stuff.
Old Oct 19, 2010 | 05:49 PM
Primetime91's Avatar
Car: '88 Camaro (Gone...)
I like it
I see the volts gauge, but what's the other one?
I like the gauge choice too. Thank you for not using gauges with all the chrome bling.
--Just my opinion here, but I think that'd look really nice with Autometer "Z-series" gauges. I bet you could fit 3, and angle them towards the driver with these... http://www.summitracing.com/parts/ATM-2234/ Now that would look nice, and the gauges don't look out of place in our interiors at all, I loved mine. But like I said, I like how you have it set up too.
Old Oct 20, 2010 | 02:07 AM
P-ROC's Avatar
Car: 86 IROC-Z28
Engine: LB9
I mispoke when I said they were 2 5/8. They are 2 1/16 gauges in there already. I was wondering why I didn't find all those 2 1/16 gauges when I was first making it because I was looking for something a little smaller before I made it. The gauges that are in it are oil pressure and water temp. I just used those two temporarily to make it. When I got the car the stock gauges werent working. I have fixed the wiring runing them so I don't have a need for the other two gauges other than filling my holes. Future plans are to install a Air/Fuel gauge and a Nitrous pressure gauge and I think that since everyone is recommending it, I am going to remake the gauge plate so the gauges tilt toward the driver position.
Old Oct 20, 2010 | 09:47 AM
Tobias05's Avatar
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
quality work. very classy. I fall into "make it look stock" quota as well, lol.
Old Oct 20, 2010 | 03:11 PM
n1ffer's Avatar
Car: 1983 Crossfire Recaro T/A
Engine: 5.0L Crossfire
Transmission: Upgraded 700R4
Axle/Gears: 3:23
Hi - looks very nice. Can you share what textured paint your are going to use?
Old Oct 20, 2010 | 03:14 PM
silentkillzr's Avatar
Car: 1984 Firebird (89 Formula Clone)
Engine: 357
Transmission: m29 T56
Axle/Gears: 3.27 9 bolt Borg Warner.
Thats sweet!!!
Old Oct 20, 2010 | 04:31 PM
usacamaro's Avatar
Car: 92 rs & 89rs
Transmission: auto & t5
i been trying to figure out where to put my toggle switches at . should have 5 or 6 toggel switches and this should work perfect . looks great man i think i might have to steal your idea for my switches. could you tell me what guage metal you used to make this.
Old Oct 21, 2010 | 04:01 AM
P-ROC's Avatar
Car: 86 IROC-Z28
Engine: LB9
I was going to try the Krylon Outdoor Spaces Black Textured #2911 first. If I don't like it I will go with something else. Each brand has a little bit different coarseness to the texture, Krylon looks like the closest match so far.
Go for it and post pics on this thread. It will be cool to see other ideas. I will have to get back with the metal gauge. I'll ask the friend that cut it all out. He will know off the top of his head.
Old Oct 21, 2010 | 10:05 AM
grover85's Avatar
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
Axle/Gears: 9 Inch w/ 3.55
Sweet mod. Sorry but I might be stealing this idea for my car.
Old Oct 21, 2010 | 02:39 PM
If you're looking for the perfect paint match...
I used Rustoleum "professional grade" undercoating, what you can buy in a can at Autozone for 6 bucks or something.
Spray that on, and it's a pretty darn good match by itself. But if it gets dirty, it's difficult to clean, and cloth and lint catch on it very easily.
So what I did, was after spraying the undercoating and letting it dry, I sanded lightly with 400 and then 1000 grit sandpaper (washing it off very well) to smooth the surface down, while retaining the textured finish. After sanding and thoroughly cleaning/washing it off, it's going to be a much lighter gray than you started with. But wipe it down with armor-all, buffing it almost (this takes a little time) and you can bring it to nearly a perfect match to the factory interior, and it cleans easily to boot. From a few feet away or the outside of the car, you couldn't tell the difference.
I did this when I made my custom gauge panel, I loved it
Old Nov 28, 2010 | 12:29 AM
usacamaro's Avatar
Car: 92 rs & 89rs
i know its been a while sence i said i was going to steal this idea but i finally got it finished and thought i would share some pics.Name:  053.jpg
Old Nov 28, 2010 | 12:31 AM
usacamaro's Avatar
Car: 92 rs & 89rs
i will install it tommorrow and post some of it in the car. i now need a new shifter boot real bad. and i have an idea for a custom shifter **** but that will be later.
Old Nov 28, 2010 | 06:01 AM
Awesome-X's Avatar
Car: 87 Camaro
Well the plate looks great but that is one awful looking shifter boot
Old Nov 28, 2010 | 06:05 AM
P-ROC's Avatar
Car: 86 IROC-Z28
Engine: LB9
Did you mount the switch panel to the original shifter plate or did you fab the whole thing? What are all the switches for?
Old Nov 28, 2010 | 05:48 PM
usacamaro's Avatar
Car: 92 rs & 89rs
i just fabed up the plate for the switchs because i used a 5speed base it would have been alot more work.
as for all the switches there for the halos on the bmw headlights i will be installing , fog lights, neons in the car and under the car , and strobe lights. i want everything on different switchs so that when i go to the cruse inns and car shows i can turn on everthing seperate.
Old Nov 28, 2010 | 05:53 PM
usacamaro's Avatar
Car: 92 rs & 89rs
the shifter boot will be replaced and i am going to make a shifter handle out of a white snooker{bumper pool}ball. snooker poolballs are smaller than a normal 8 ball .
Old Dec 4, 2010 | 11:58 PM
rock861261's Avatar
i made a switch panel that sits in my ash tray so i can close it and it looks stock
Old Dec 18, 2010 | 06:28 PM
sam85iroc's Avatar
Car: '05 Audi A6
Engine: 3.2L NA
Transmission: 6spd tiptronic
Axle/Gears: quattro awd w/esp
for the tilt toward the driver you can cut the gauge openings as ovals/eclipses to fit properly sized metal tubing at the desired viewing angle. Then fit the tube through the flat panel kinda like rooftop vent stacks. the end result will be angled like the pillar gauges but on the console
edit: oh someone covered this:/
tommy z-28
Oct 6, 2015 10:58 PM
chuck13
Interior Parts Wanted
Sep 22, 2015 11:19 AM
88HARDTOPIROCZ
Sep 18, 2015 10:30 PM
Third_Gens_Rule
Sep 3, 2015 06:56 PM
Third_Gens_Rule
Sep 3, 2015 06:55 PM
